Chain fence eating turbo
Originally Posted by baloo View Post
"Fuel quality switch"? I'm ignorant, so bear with....
Does this switch actually exist on a stock DME?
Thanks.
Yes
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-09-2019, 10:13 AM
greglepore's Avatar
Just got my gt35 fitted to an older protomotive conversion. Had to rework some of the exhaust to clear the tire. Wow, great improvement over the older turbo. Full .5 bar almost immediately from 3k up in the upper gears. Thing flies now.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 07-27-2019, 07:40 AM
Brando
quattrorunner's Avatar
You had to rework the exhaust to clear the tire? I’d like to see what you had to do there.
Turbo powa!
1977 911s. it's cool
Old 07-27-2019, 07:41 AM
greglepore's Avatar
Originally Posted by Lyle O View Post
BTW, as an update on the AFRs on boost: working with Todd, we utilized the "fuel quality switch" on the back of the DME, and went to a richer (+6%) setting. It completely solved the issue; I now have AFRs on full boost at 10.1-12.5. I sure do love how this thing runs! Such fun.
Lyle-did you use the position for +6% or +6 with ign retard? About to adjust mine. I don't actually have an afr meter but my plugs have always looked slightly lean.
Greg Lepore
85 Targa
Old 07-27-2019, 07:46 AM
Actually, I dialed in the position with 6.3% enrichment and 2.79 degrees of retard. The retard affects the overall HP output, but adds some safety again detonation. When I dyno, then confirm everything else (fuel system pressure, and fully plotted AFRs and boost), will probably reduce the retard at the switch to zero, but add a bit back in the EPROM. It runs really solid now, though.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 07-27-2019, 09:54 AM
greglepore's Avatar
I'll send pics later. Car has stock heat exchangers and the original protomotive kit barely cleared my rears. The gt35 was just enough wider that I had new stainless fabbed to move it inboard a schooch. Will have car on a lift tomorrow or monday and post pics.
Greg Lepore
85 Targa
Old 07-27-2019, 02:27 PM
scottrx7tt's Avatar
At 10:1 you were probably blowing a lot of black smoke out the exhaust. You are leaving a lot of power on the table at that AFR also
Old 07-27-2019, 04:53 PM
All seems a little baling wire and duct tape.
3.2 is an EFI car. There was a piggy-back in-circuit emulator for the Motronic developed a few years ago (guy posted on the 911 forum) which would let you tune maps interactively, log and all that modern stuff - then burn an EEPROM when done.
But given that you've already got most of the sensors, just adapt the factory harness to any ECU developed in the last 20 years.
You wouldn't even need to add MAP/TPS, cam sync or switch to modern injectors all at the same time, do that incrementally later.
'77 S with '78 930 power and a few other things.
Old 07-28-2019, 10:38 AM
greglepore's Avatar
Had to lengthen inlet to turbo and change it from 3 bolt to t3, and that required redoing the exhaust plumbing. Had I known, I would have gone with a v band compressor side.
Greg Lepore
85 Targa
Old 07-30-2019, 09:21 AM
Brando
Oh wow that's interesting location of turbo. Is that protomotive kit location?
Turbo powa!
Old 07-30-2019, 10:06 AM
greglepore's Avatar
Yes...but a very old protomotive kit, early 2000's.
Greg Lepore
85 Targa
Old 07-30-2019, 08:33 PM
Was that the unit from RaceBoy in Lithuania?
I'm still interested in his unit and wanted some feedback from those who have installed one.
Old 07-31-2019, 06:55 AM
RaceBoy's ecus are not piggybacks; they're VEMS full standlone with an adapter harness. I'd stay away from piggybacks for countless reasons. As far as VEMS goes... No issues with mine so far other than issues I've created myself (ie. wanting more boost and blowing plenums apart lol)
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW
Old 07-31-2019, 08:26 AM
GTK, thanks. Not at that point yet, but inching forward.
Old 07-31-2019, 09:03 AM
No, Sal (scarceller) in this thread, starting post #132 tuning programmable engine management systems
993Speedster is right; a piggyback that lets you tune/live-map the Motronic does have an application - but a very specific/limited appeal. And tons of compromises for forced-induction applications.
Stand-alone management would be better in almost every way.
Raceboy seems well on top of things & knowledgeable; I'd made a note of his kit, but ended up with something else.
Old 08-01-2019, 08:48 AM
