Where to connect?
Can anybody tell me if this connector is just an optional one or what? I found it yesterday when i was doing some work on the BOV. It`s dusty, so I don`t know if it`s in use...?? Can`t find anywher to connect it...
Old 12-16-2018, 11:37 PM
Old 12-16-2018, 11:46 PM
Just an idea. Can it be the connector to the rear blower motor. Maybe the 930 don`t have this motor, and the wire just are there and not connected because the 911 and 930 has the same wire harness.
Old 12-17-2018, 04:09 AM
totle's Avatar
Did not see you posted Raymond, so I posted one recently as well :-)
Now you might have double answers :-)
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-17-2018, 05:02 AM
full quack's Avatar
Send a message via Yahoo to full quack
Your missing 2 nuts on your recirculate piston housing as well!
Mark
Old 12-18-2018, 08:54 AM
Hello Turbo friend
Looks like the it would goes to your vacuum solenoid that is used for the emissions diverter coming from you air pump.
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 12-18-2018, 11:59 AM
stevie 77 930's Avatar
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-18-2018, 02:08 PM
That one's not for the airpump, its to block vacuum retard to the distributor I think. Its inline between the nipple on the dizzy can closest to the dizzy body and port I on the rear LHS of the throttle body. Controlled by the thermo switch in the chain housing LHS if I remember correctly.
The vacuum solenoid-valve (37 in the hose plan diagram for an '86 930) is plumbed thusly:
-Nipple underneath the electrical connector to the throttle body
-Nipple opposite the electrical connector vents to atmosphere
-Nipple on top at 90 degrees to the distributor
Old 12-18-2018, 05:30 PM
Yes. Its that one. Its removed on my car so i belive its no where to connect it
Old 12-19-2018, 06:23 AM
Mark
I know. In the middle of a job with it
