T77911S's Avatar
WG opening?
I could not hear any farting on vid.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-20-2018, 02:56 AM
The exhaust and motor sound in the video sounds normal to me.
I don't know what you mean by the exhaust sounding like farts.
Human farts can sound like anything from a little squeak to a huge FRABALADAPPP...
If you're talking about the popping in the exhaust during deceleration that's totally normal from a 930 or 911 turbo with the original CIS fuel injection.
I believe 930 deceleration exhaust popping is caused by unburned fuel exploding in the primary tubes of the exhaust headers during deceleration.
There is some unburnt fuel in the exhaust during deceleration because Bosch K-Jetronic or CIS (Continuous Injection System) is an old mechanical fuel injection system that was a compromise and far from perfect. It's air fuel mixture never stops spraying some fuel if the motor is running and it leans out a lot during closed throttle deceleration.
Old 12-20-2018, 07:09 AM
Seth Hamilton
Thank you all for the continuous feedback.
The noise is definitely not rubbing.
I am not trouble shooting the deceleration popping as it sounds great - A sound I know and love. I am talking about the Honda with a cheap muffler sound that comes about when on boost. This sound was there before and after the fabspeed exhaust, just now louder with the exhaust. The video I took did a poor job of catching the sound, perhaps I will have someone film from outside the car.
I will start to really dig into it and figure it out.
Collector of stuff most don't care about.
Garage- 2018 GT3 (6spd,LWB, Chalk). 69 911t Hot Rod. 964 Turbo. 79 930. 88 M3. 72 280 SEL. F80 M3 (Modded). Boring daily driven things. Other 911s sadly sold.
Old 12-20-2018, 08:13 AM
clutch-monkey's Avatar
swap out a muffler and see if it's still there?
Old 12-20-2018, 11:59 AM
Seth Hamilton
It was there with the OEM muffler and still there with fabspeed
Old 12-20-2018, 12:10 PM
kevinbodman930's Avatar
I hear it.It almost sounds like a excaust leak.By chance are you running the stock headers?if so they could be cracked.I dont think it broken head studs.Do you have a way to put her up in the air?to check for cracks or even loose excaust manifold?
Old 12-20-2018, 02:49 PM
If you check that the exhaust header nuts are tight and any of the nuts turn and don't become tight the exhaust port stud threads in the heads are stripped.
If the female threads in the head are pulled or stripped an 8 x 1.25mm time-sert can fix it and make the threads stronger than they were because they are hardened steel instead of aluminum.
https://www.amazon.com/Time-Sert-M8x1-25-thread-repair-1812/dp/B01MSPN7NH
ebay has them too.
Old 12-20-2018, 04:02 PM
I’ve been following this thread wondering what the answer is to the farting noise, which btw, I don’t hear. Those that do must have some well trained ears. Hopefully it’s nothing major like head studs.
I never realized how much I need a trunk monkey, that little guy is great!
Old 12-20-2018, 05:24 PM
lake wales fla
+1 trunk monkey, everyone should have one, world would be a safer place
+1 head studs
Old 12-21-2018, 01:11 AM
Banned
OEM headers?
sounds just like Jacob's old car w/ SSI's and RL8 muffler IMO - mine w/ OE and then Powerhaus headers and RL8 muffler sounded entiiiirely different than his... his had that distinct vroooom sound like yours
if OEM, then yeah I'm guessing maybe manifold leak @ flange?
Old 12-23-2018, 06:36 AM
the sound of the exhaust is really nice !!
The sound is certainly a metal that vibrates.
Have you already checked the heat shield...
Old 12-26-2018, 12:42 AM
Anybody know where I can get a frunk monkey?
Old 12-26-2018, 06:36 AM
930 Exhaust sounds like a fart - Help
I do hear some sort of noise that is timed with the exhaust. It sounds like a metal vibration. I would look for something that is close to touching, cracked or loose. I may take the torque of the engine to make the two pieces touch and make the noise.
I did have the intercooler charge pipe slightly out of position where it would rub on the body, near the engine mount, and make a similar noise. But mine made the nose at idle not boost.
Derrick
Old 12-26-2018, 06:56 AM
Seth Hamilton
I figured out the issue. It was a small crack on the headers, small enough to only make the sound while under boost. New fabspeed setup going on soon. Problem solved, thank you all for the help!
Old 03-11-2019, 11:56 AM
Armed Bastard
djb25's Avatar
Thank you for giving the update. I just read through this thread and was worried there would be no conclusion. Glad you figured it out.
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 04-25-2019, 09:01 PM
I put the Fabspeed supercup on my 89 930, love the sound. Very happy with it.I had a stock muffler with a Fabspeed cat delete prior. I am going to list the cat delete on the parts classified this week.
Thanks,
Larry
Old 05-06-2019, 03:55 PM
Crotchety Old Bastard
RarlyL8's Avatar
Cure for cracked headers
Want headers guaranteed not to crack? Produced by a 20+ year Pelican member. 321 stainless, TIG welding, and a proper tuned design that also helps reduce boost creep.
And if you want to shave 20 pounds off the rear with a choice of 3 sound levels and 4 tailpipe configurations, also in 321 stainless and guaranteed never to crack this is the ticket.
Old 05-06-2019, 05:04 PM
Alan L's Avatar
Brian, your work is superb. I have your headers (and zork) on my track beast (7+ yrs now at least).
No issues, and only run at WOT basically. And nice to perv at under the car.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-06-2019, 08:09 PM
I know absolutely nothing about exhaust but that is art work, beautiful.
I wish porsche would have conceived beautiful artistic exhaust like this.
Sent from my iPhone using Tapatalk Pro
http://9309700485earlyturbo.wordpress.com
Old 05-10-2019, 05:22 PM
