Microsquirt and 60-2 VR Sensor - What value shunt resistor?
I'm using a Microsquirt v3 with a Porsche 993 etc VR crank pickup and my flywheel cut to 993 etc 60-2 tooth pattern.
I got a great start and picture perfect composite logs at low RPMs but ran into signal breakup and the "fake rev limiter" behavior at around 2,600 rpm.
I added a 10k ohm shunt across the pins in-harness for the crank pickup and that raised my "rev limit" to about 4,600 rpm, but its still there.
If you've gone down this path, what value shunt resistor did you end up with to eliminate this problem?
Cheers!
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 05-12-2019, 05:22 PM
I would rather be driving
jpnovak's Avatar
Did you enable the internal jumper that connects the high tooth count internal shunt? You can see it at the bottom of this pic. The place that says "JMP HERE" VR sensor. VR2 is for cam input. Leave it alone
The 10K is likely too high. It will change the internal voltage resistor divider. Usually you should start with a R value that is close to your VR sensor Resistance value.
I am going to guess your VR sensor is in the 800Ohm range. Try a 500 or 1K resistor if the internal shunt doesn't work.
Old 05-13-2019, 06:10 PM
Thanks Jamie
I chose 10k because that seems to be a widely recommended value on the msextra forums, but I couldn't get a clear understanding of whether I should go higher or lower given what I'm observing.
My logic says I should go lower, because that will bleed more voltage off to ground, reducing the voltage saturation issue at high RPMs. But, there's all sorts of contradictory recommendations on the forums
Old 05-14-2019, 07:58 AM
jpnovak's Avatar
That there is...
The only real way to set this is to look at what voltage is coming off the VR at your max rpm, add some margin and then calculate a resistor value that makes the divider limit at this voltage.
BTW, Have you enabled the FW tach period rejection filter in the microsquirt? I use this on my Hall Sensor installs. Basically, you have a tooth every 6 degrees. Calculate a time period for your max rpm plus 1000. then enable the curve to reject short pulses as a function of rpm. It works well.
Old 05-14-2019, 09:19 AM
Thanks for the tips Jamie.
Old 05-14-2019, 10:25 AM
Jumpered the board, left the 10k in parallel with the sensor, configured noise filtering.
May possibly have raised my "fake rev limiter" a couple hundred rpm, but its still in the high 4,000's close to 5,000 rpm.
Frustrating.
Old 05-18-2019, 06:23 PM
jpnovak's Avatar
try putting a 1K in series (in line) with the positive side of your VR sensor. This will limit the voltage.
Do you see signal loss or jumps to high rpm when you hit your 5k rev limit? The composite or tooth logger should show. Do you still see the -1 missing tooth?
Are you running a second VR sensor for sequential
Old 05-18-2019, 08:35 PM
So this weekend I pulled out the MS and added the jumper on the board. Negligible if any difference.
So, my next step was to remove the 10k resistor I had put across the pins on the sensor connector. I installed a 2pin molex connector here so I can adjust the resistance easily while testing. It also makes a nice location for oscope connections.
Without any additional resistor other than the on-board shunt I'm back to a 2,600 rpm "rev limiter". So, I'm not really sure what the on-board shunt does. Didn't seem to have any effect for me.
I measured the resistance across the two pins on the CPS while disconnected from the Microsquirt - 1098 ohms.
I also captured some oscope logs while idling, not the image I expected.
I did note that I got loss of sync as the voltage from the sensor approached 100v.
I'm not running sequential, no second sensor.
Jamie, to confirm, you are suggesting in-line NOT in parallel with the sensor? Ie this is NOT shunting voltage to the ground side. Or are you suggesting that IN ADDITION to the 10k shunt across the pins?
There is a TON of misleading and conflicting information about curing this issue.
Old 05-20-2019, 07:37 AM
jpnovak's Avatar
Super helpful information here.
I do not know what the Vin (max) voltage limit for the microsquirt VR circuit is. The fact that you hit a hard limit at 100V could be at the limit - especially when common component choice could be close to the Vrms of this 100Vpp signal.
So, we need to drop the voltage of the signal. There are 2 ways to do this:
1) Move the VR sensor further away from the toothed wheel. The VR signal is non-linear with distance following a magnetic power law. Basically is close to a square function. Double the distance and you cut the signal. What is your sensor clearance? Try adding 1 or 2mm and this should help.
2) Build a voltage divider into the VR wiring input before it gets to the conditioning circuit. The VR sensor signal is very clean in your scope trace. There is a slight slope change on the up-slope but I don't think that is enough to confuse the ECU. You added part of the voltage divider circuit. This is why I suggested to add a 1K in series with the signal.
Consider three connections to the circuit. Vin = VR sensor output. Vout = Signal going to the ECU. Ground. You added half of a resistor divider network. Your 10K resistor is basically R2 in the following circuit where R1 is just a wire connection (R1 = 0). You need to move this to the R1 position and add R2. Connect them as follows.
A 1K resistor will cut the voltage by 1/11 according to
Vout = ]R2 /(R1+R2)] * Vin
This will give you ~10V signal at your 2600 rpm cutout point and should give plenty of voltage headroom at your presumed 7k-ish redline.
Old 05-20-2019, 08:50 AM
Ah, NOW I see what you're suggesting. Excellent, I'll give that a try. Before I do I'll take a couple of scope readings at different RPMs and see if I can predict what the uncorrected voltage would be at 7k rpm, and adjust the resistor values to try to keep it below 90v.
Yes, I noticed the slight difference on the upslope. I want the cleanest zero crossing possibly and it's easy enough to swap pins while I'm doing this change, so I'll do that.
I'm using the stock Porsche sensor mounted on the stock boss so moving the sensor would require modifying the sensor and probably not easy to do now the motor is back in the car.
I'll post back with updated data next weekend. In San Fran all week.
Old 05-20-2019, 09:43 AM
Composite tooth logs look fine, but I don't have a log for when it breaks up. Must have lost it. Interestingly I just noticed I think the onboard shunt makes the tooth logger look different.
Before shunt:
After shunt:
Old 05-20-2019, 09:57 AM
jpnovak's Avatar
The signal looks inverted with the shunt.
Old 05-20-2019, 10:27 AM
Yes, but it doesn't change the running behavior. And it's a PITA to take the MS out from where its mounted, so I'll probably just leave it.
Old 05-20-2019, 10:31 AM
I've just been fooling with this, at assumed you meant that the GND in the diagram was the VR- pin, and the Vin was VR+.
I've tried a few different dividers, .5, .3, .2 without much change. In rethinking, I may have made an erroneous assumption.
Are you taking the GND in the diagram above to actual engine ground, and not to the VR- pin? Such that, VR+ off the sensor is modified by the voltage divider, and VR- runs straight from the sensor to the Microsquirt?
Old 05-25-2019, 03:59 PM
Getting quite frustrated by my lack of solution to this, and the level of disinformation, and general dearth of documentation on the Microsquirt product has me very frustrated.
To date I've tried:
-nothing other than connecting sensor - sync loss 2,600 rpm
-10k across the sensor pins - sync loss 4,000+ rpm
-bridge the shunt on miscrosquirt board - I'm buggered if I can tell any different with this thing
-voltage dividers across the pins of the sensor
-voltage dividers going to engine ground
Whatever I do, I can't get anything to work reliably. My next option is to
-remove the useless bridge on the MS board
-remove the current 1/3 voltage divider that bleeds to engine ground
-try a very low resistance shunt across the sensor pins (like 1k)
-come up with a conditioning circuit of my own, possibly utilizing optoisolators, varistors, transistors to generate a clean 5v or 12v tooth pattern for the MS
IDK why this is so difficult, this isn't some esoteric setup I'm running.
Gaaaaaaaaaahhh!
Old 05-25-2019, 07:47 PM
Decided to quit screwing around and build a conditioner using a MAX9926 https://www.digikey.com.au/product-detail/en/MAX9926UAEE+T/MAX9926UAEE+TCT-ND/3879279
Old 05-27-2019, 09:46 AM
Chain fence eating turbo
Are you sure you are keeping the VR away from high EMI emitting components like the coils?
I've used ferrite beads on the VR sensor wiring, faraday cages around my coilpack, and low pass filter on the VR sensor wiring. Nothing ever seemed to change in my setup, so I figured I was wasting time with it and left it alone.
I was having a massive explosion when coming on boost like NOS that I thought was VR related. It probably is simply in my tune.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 05-29-2019, 08:23 AM
oh yes, totally isolated harness separated by at least 6 inches and only really gets close at the terminating end.
boy I get a massive backfire when I loose rpm signal, made worse as I don't have the exhaust on right now. First time it happened my gf came running in, thought there was an explosion. The cops came over and said they had reports of shots fired
Old 05-29-2019, 01:40 PM
I'm not going to get involved any specifics of your ECU or advice there, however for VR signal conditioning I could recommend this as worth looking at :
https://sirhclabs.com/product/cortex-ebc-speed-sensor-adapter/
We had a similar requirement in needing to convert a VR signal into a consistent voltage square wave for a high speed cylinder pressure instrumentation system. Used the above device - have viewed and logged in high speed scope at over 10,000rpm - and it worked very well for what I thought was an extremely reasonably cost and no hassle factor.
Old 05-29-2019, 08:49 PM
Yes that uses the same chip I plan on using. Its a very simple circuit, needs only 2 additional resistors.
Old 05-29-2019, 10:40 PM
