E-85 sippin drunk
CoP project
I decided to make the jump to Coil on Plug. Of course, my first, and only call, was to Chris Carroll at Turbokraft www.turbokraft.com . He knew everything I needed to have, including the little hex standoff spacers to make the RSR hold down brackets fit the CoP's. There are SEVERAL different lengths of CoPs, so not that its a secret, but Chris has already done the leg work to find the coils that fit the best and properly.
I went to www.prowireusa.com for my wire, heatshrink, and connectors. I used the best stuff out there (Raychem DR25, Tefzel wire, Deutche connectors, etc). I will tell you that it pays to use the good stuff. There is absolutely NO comparison between this and the crap you can buy at any parts store. Shout out the Chris for helping me with this. Its awesome to be able to call someone who actually knows about what he sells. Thanks brother, I really appreciate you!! Dumped my phone in the pool over the 4th of July, so lost all the pictures I took of the install. However, I did make a post on IG.... so click the link for a few pictures of the process!!! I will tell you that the difference was IMMEDIATE and profound. Rock solid idle, and absolutely ZERO issues. IG link..... https://www.instagram.com/p/B_wBPOFl1A8/?igshid=o61mowz1r4dl
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
hear hear! Absolutely worth the extra few %. Especially a few years down the road when cheap PVC and other parts become embrittled, fatigued, and deformed from heat cycles.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Clean install!! What coils did you use? Is the Link G4 EFi system setup to trigger 12 coils??
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
One of my favorite 930s.How is the new clutch holding up?
Sent from my SM-N976U using Tapatalk |
E-85 sippin drunk
![]() (this is also an older ECU, so they may have a newer model out that might be able to run more). On my old setup, I ran an M&W CDI pro16b box. I split the outgoing signal to a pair of 3x3 Bosch coilpacks, which actually HALVED the power to the coilpacks. In order to be able to run a true direct spark with full power available from the high power CDI boxes, I would of had to buy another CDI box, and run two of them.... at $1300 or so for a second box, I choose to do CoP. I got rid of all the HT leads, the coilpacks, and lessened the chance of noise from the HT leads. All while bringing the ignition system into the modern day, not that there is anything wrong with a CDI system.
E-85 sippin drunk
We hit right at 500HP at the crank, before the clutch started to slip.. on ONLY 6psi ![]() ![]() ![]() So, I think we are on target for a very well performing engine
That is fantastic has she always been on E85?500 at 6pnds is really a great # i can't wait to hear what she put down full boost on E85.
So what coils are you running??
Denso COPs
If you need some, give us a call or email.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Brad's car is incredible. Very inspiring.
Ole Skool - wouldn't have it any other way |
E-85 sippin drunk
Thank you, Sir!!!! I wish my car was as perfect as some of these pictures make it look like.... but I will tell you that the side skirts have rock chips, etc... This car is driven, and is used like it should be. Definitely NOT a garage queen.. LOL Picture is by Nick Rico Photo
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk Last edited by turbobrat930; 10-07-2020 at 02:57 PM.. |
E-85 sippin drunk
Chris answered your question before I got back on here. Yes, they are Denso coils. They fit perfectly!
Banned
really great to see you back on here, with inspiring work as usual there sir - keep up the good werk!
I’m using the Denso 673-1301 COPs.
I based dwell time off threads like this one: https://www.miataturbo.net/megasquirt-18/dwell-observations-toyota-cop-44131/
Turbofrog
DO you know how to decode those denso numbers and have those worked nicely for you?
I found some cheap toyota v6 cops but no info on the lenght or other specs: https://www.densoproducts.com/denso-673-1308-ignition-coil EDIT: found a nice pdf for dimensions: https://www.newera.co.jp/en/product/communication_site/pdf/419.pdf Another link for newer coils https://www.newera.co.jp/en/pdf/catalog/New-Era_IgnitionCoilSeries.pdf And my own pics from those: 02239 105mm 02240 113mm 02243&44 117mm 02234 119mm 02246 120mm I'd rather buy new ones to avoid any COP troubleshooting when wiring and almost every fuel/ign. component is new.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 02-23-2022 at 03:05 AM.. |
They work great esp with Chris's hold downs. I did find I needed to massage the bend angles in the hold downs a little.
Ingenieur
Great links! FYI for new COP adopters, in addition to the fit, there are two kinds of coils. One kind has the switching transistor built into the coil, the other requires a control module that can deliver a 12V high current supply directly. You generally want the built in switching transistor coils, which have either three or four wire connectors. Because the module provides a 5V low current signal for these, the output can be split for two coils from the same control module output pin without affecting the coil output.
