The Bulletproof Valve Adjustment Solution
Hello air-cooled friends
I'm thinking of using this tool to adjust my valve's next springs when I pull my engine to change the clutch and the engine carrier.* Please give me your thoughts.* The Bulletproof Valve Adjustment Solution For Your Porsche!**See Short Videos Demonstrating How and Why SNAPGAP Works and . . . a One Handed Valve Adjustment in 1 Minute 10 Sec.* https://snapgap.us/ https://snapgap.us/pages/snapgap-installed-on-911 https://snapgap.us/pages/how-and-why-snapgap-works-1 Best regards Helio
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
The only thing that worries me is the possibility for that little shim to fall off.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Hmmm, pretty cool method.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Am I the only one that finds the standard factory way with a bit of shim material or a bent feeler gauge to be quick and easy-peasy?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
It's a 914 ...
I guess it's what you are used to and feel most comfortable with. IMHO, doesn't get much simpler then the factory method, plus easier to track valve stem/seat wear with the factory method, as you are actually feeling the drag. At least that what I have done for the last 45 years.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
+1
All these hey-look-at-my-new-gizmo methods seem like unnecessary complications. How much time are you really saving on a task that doesn't take that long to begin with? If you cannot judge how much drag is on the feeler gauge, should you even be doing maintenance on your 911?
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Slantnose from HELL
^+2
It changes from time to time..... |
Agreed, never used one of those gadgets in over 40 years. Bent feeler is so simple. Or use the feeler holding tool. If you don't feel comfortable judging how the .004 should feel then use an .005, if it goes in it's too loose. if the .004 won't go in, it's too tight.
