Hey gang,
I have been lurking for a while while I decided to “ruin” my stock 80sc motor by adding a turbo. (Joking it’s been awesome) Basic stuff: Stock 3.0 Turbo Thomas Headers Comp oil less 3.0 turbo Hacked down CIS manifold with aluminum air box Bitz EFI with Megasquirt 3 Coil on plug Cheap eBay inter cooler Running .5bar wastegate spring The power has been amazing. Really though I didn’t know anything about the engine. I have battled some detonation that seemed to clear with 100 octane or a booster with crappy CA 91. Rings on cylinder 4 met their demise a few days ago while hooning it a bit. Looking for advice on what to include for a full rebuild? My thoughts: Forged pistons but lower the compression Twin plug ARP hardware Stock 3.0 rods ? (Do I really need fancy ones for a 400hp crank motor?) Pictures: ![]() ![]() ![]() ![]() Last edited by matthepcat; 12-14-2020 at 11:55 PM.. |
Introduction, Cooked a ring, rebuild advice turbo 3.0
Air guides for the intercooler.
Nice looking setup. |
Pics of the 914?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Thanks, yea I need to start brain storming how to do that. I thought about fabricating a scoop of sorts to grab air and force it through.
I do have a port ready for methanol injection, so maybe the combo will be enough to eliminate possible heat issues. |
1. Upgraded intercooler -- maximize the surface care, reduce charge air temps so they're more consistent into the engine
2. Yes, lower compression pistons, 7.5:1 or 8:1, with better If the cylinders are damaged or out of spec, then over-bore to 98mm and make it a 3.2L. 3. Twin plug is always a good call when you've only got 91-octane to work with Check the valve springs, chances are if they're original then the pressures are all over the place. Upgrade them to some good ones. 4. ARP has been a consistent excellent product, while others like Supertec. We would avoid Raceware. 5. ARP rod bolts in stock rods. 6. Inexpensive insurance: dry film coatings to increase lubrication, reduce friction -- rod bearings, piston skirts. That's a durable budget 3.2L Turbo
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Thank you for the suggestions and advice! I may contact you directly about the coatings.
Did you import those headers from the UK they look awesome
Consider adding a knock sensor to help with tuning. I am installing a J&S ignition with the knock sensor mounted to engine under the throttle console. There will be a display in the dash to indicate knock, it automatically pulls timing from the cylinder that's knocking. Also has a boost reference line that will allow for more timing advance off boost, then it pulls the timing back once on boost.
Little bottles of octane booster are a scam, do a bit of reading on turbo engines and octane. Toluene is what you want to add. https://www.worldofchemicals.com/428/chemistry-articles/toluene-additive-for-racing-fuels-fuel-octane-booster.html#:~:text=Toluene%20is%20such%20an%20ef fective,to%20ignite%20at%20low%20temperatures. David Performance EngiNerding Last edited by reclino; 06-04-2023 at 06:44 AM.. |
Funny this thread comes up. I know it was old. But I think mine just recently happened the same exact way on cylinder #4. Assessing situation tonight with leak down/compression check.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
Welcome to the club!
The only upside is now you can run new cams and forged bits + knock sensors. Godspeed!
Turbo bodied 1980 911SC, 3.0, Twin Plug, Garrett GTX3071r, JE 8.5:1, TurboThomas headers, Modified CIS intake, MegaSquirt 3, Coil On Plug. |
Your car has been running quite a while now on a unopened early SC engine though correct? Hard too, with track time even. Pretty impressive with the life you got out of it being boosted.
![]() Here was my motor before it went back in the car.
These headers are very neat and beautiful. I have been battling knocking myself with my boosted Euro 3.2 (10.3 CR with 7 psi of boost), I'm using a Torco octane booster can with every tank fill and use full bay intercooler (made HUGE difference than the half bay one). Also your intake filter sucking hot air from around the exhaust, that's not helping against detonation, it will help a ton if you move it to inside the engine compartment.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
So mine was actually #6...but anyway...
That looks great, Matt! How long has it been running now and has it been dynoed? Are you running MSIII now with both fuel/spark control?
And this is with regular track duty. I admit I've slowly turned up the boost at the track where it runs in the 300hp range, so if I left it at minimum like I normally do (~280hp?) it may have gone longer. The street I always turned up up to about 330-340. I'm at about 195k miles right now. I guess it's time.
Banned
Where did you get headers from? They’re nice
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Crotchety Old Bastard
... or you could go with true equal length tuned headers, listed by our host, having smoother angles for the waste gate pathway, primaries that don't cook the S oil hose, shorter equal length secondaries, and optional heat exchangers.
![]() ![]() Yes if changing out P/C would be a great time to lower the C/R and safely bump the boost level. Will get the same power on lower octane fuel and more conservative timing.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thread Tools | |
Rate This Thread | |
