930 Turbo upgrade and NO Turbo Lag!
Hi
Recently went out in this car which has some great upgrades and it feels like it has no lag at all.
https://youtu.be/qfvTr3TU0Hg
What do you think, this 6 blade fan makes a massive difference
Scott
www.outlawgarage.com.au
Old 06-11-2021, 03:05 AM
NO is a big word, I might double check this
Old 06-11-2021, 05:44 PM
crb07's Avatar
Gets into boost faster than you can check your email on 5G?
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 06-12-2021, 03:56 PM
Crotchety Old Bastard
RarlyL8's Avatar
Didn't show the tach so hard to say. My guess is that what is being described as "on boost" is actually boost threshold. 1.0bar boost probably comes a bit under 3000rpm. We use the same type turbos (with tuned headers not short tubes) and that's what is seen. 460hp at the wheels is questionable unless that -037 (Euro) fuel distributor is highly modified. The cherry red headers indicate a problem with the AFR or timing. Only after several dyno runs or track use should you see some red in the exhaust and even then nothing like that. Beautiful car that runs strong but I'd look into that tune before something melts down.
Old 06-13-2021, 08:41 AM
16Volt's Avatar
I thought it looked impossibly lean to glow like that at idle. Lean is mean.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 06-14-2021, 01:36 AM
Turbofrog
smurfbus's Avatar
It might be retarded too much and that contributes to low boost treshold too. When I got my car it used to run on boost on normal highway cruise. It had the distributor wire connected wrong so the timing was way retarded.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 06-14-2021, 03:02 AM
