Happiest when Tinkering
gsmith660's Avatar
AFR on gauge different than tunerstudio
The gauge reads typically 1 to 1.5% richer than the reading in tunerstudio I have MS 3 and I saw a setting in the: General settings>Input smoothing lag factors>Lambda averaging lag factor. I am curious if this could be the cause it is set at 60 right now
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 01-07-2013, 10:54 AM
Go into Tools then Calibrate AFR and make sure you have the correct gauge settings.
My lag factor is set at 50, but I don't that is what is causing your reading discrepancy.
Dave
Old 01-07-2013, 11:22 AM
gsmith660's Avatar
I am going to make a big assumption that the gauge innovate supplied is reading correct
tunerstudio is reading lean the gauge rich and the gas mileage sucks soI am thinking the gauge is correct.
Old 01-07-2013, 11:53 AM
I had too many issues with Innovate so switched to AEM and I like the no need to calibrate and zero quality problems.
Old 01-07-2013, 12:03 PM
xbmwguy's Avatar
which innovate are you using? i too had this problem until switching to the new mtx. i even used my analog guage instead of the one supplied ( stuck it behind pass kickboard wrapped in bubble wrap) and ran the yellow wire to ms2. works flawlessly
Old 01-07-2013, 12:19 PM
gsmith660's Avatar
I am using the LS-1 with the digital gauge. On the analog gauge did you drive it off of megasquirt?
Old 01-07-2013, 03:41 PM
xbmwguy's Avatar
i would highly recomend the new mtx unit for a few reasons. 1 it is much more stable and accurate. 2 you remove the "brain" of the unit from our extremely hostile environment as the " brain" is located in the guage itself. wiring is far simpler with only 3 wires and innovate highly recomens it to use in contrlling efi. i got fairman(still cis) and dmatera (efi) to switch and both are very happy. like i said i didnt like the sweeping lights and digital displat so i ran my analog, period correct looking guage from my lc1 off the extra output brown wire and run my ecu off the yellow output wire. veeery accurate now. i would say within .10-.15
Old 01-07-2013, 04:53 PM
Ken911's Avatar
So i have an LM-1 what will i have to get for use with the ms-3 i cant just plug the sensor into it? i have to get another black box of somekind? I had forgot all about that thought i had everything electronic in my pile of parts.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 01-07-2013, 07:04 PM
Turbofrog
smurfbus's Avatar
IIRC LM-1 also has a analog out that you could use.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 01-07-2013, 09:33 PM
gsmith660's Avatar
Ok the MTX unit is on my list for when the LS-1 fails but if I remember right and correct me if wrong the gauge is a digital output and the tie in to megasquirt is analog so which one do I believe is most accurate I would ask Innovate but the last time I did they just told me to send it back to them they wanted the 75 dollar fee to replace it.
Never mind they are both analog but still which one should I believe? And how long is the cable the sensor plugs into on the MTX
Old 01-08-2013, 09:40 AM
I would rather be driving
jpnovak's Avatar
Are they both (Innovate and MS-ECU) grounded to the same place?
Old 01-08-2013, 12:17 PM
gsmith660's Avatar
I think they are since that is a big warning in both install guides but I gotta check and maybe clean the ground living out in the country is hard on a air cooled car.
Old 01-08-2013, 05:08 PM
xbmwguy's Avatar
there are only 5 wires total on the mtx. red power, black ground, and white to light source,the yellow(which i ran to my ecu) and the brown to my other guage. you can get the optional 13 foot cable to go from sensor to the guage thus making install options almost endless, and once again the "brain" of the unit is nowhere near the high temps the lc-1 experiences
Old 01-08-2013, 06:54 PM
gsmith660's Avatar
I think this is a grounding issue really and I have already fried 1 sensor but I think the controller is in a relatively cool spot in the engine bay. I did make a stainless steel heat shield in addition to the heat cover on the wiring and we will see if that extends the life of the sensor as it is the sensor lasted over 3 years but I think they should last longer. But when I change I will use the mtx.
Old 01-08-2013, 07:13 PM
gsmith660's Avatar
It is supposed to be near 60 here in the next couple days so I will get a chance to get out and take a look.
Old 01-08-2013, 07:16 PM
Just did a search and amazon has a good price on it.
Innovate Motorsports 3844 MTX-L Complete All-In-One Air/Fuel Ratio Gauge Kit : Amazon.com : Automotive
They work great and it comes with black or white faces and black or silver rings.
I like analog instruments better but I can read this digital readout alot faster when glancing down at the console while driving.
The innovate sheilded extension cable to the oxygen sensor is needed in 911's
Old 01-08-2013, 07:18 PM
gsmith660's Avatar
All the grounds in the same place I am going to hookup my gas analyzer to see which one is correct
Old 01-13-2013, 08:24 AM
Navin Johnson
TimT's Avatar
I wonder if the math functions that Tunerstudio expects and the LM1 output are different?
I am mentioning this because I had a similar problem getting the AFR display on my Aim Pista to read the same as the display from my TechEdge WB controller display.
To get the displays to agree I had to tweak the math function on the Aim display so that it matches the displayed output from my WB controller.
You need to use one as a baseline... which do you feel comfortable believing?
'69 911 GT-5
'75 914 GT-3
and others
Old 01-13-2013, 04:48 PM
Ken911's Avatar
well if you calibrate it in air and check it in tuner studio it should be correct
2019 Silverado 6.2L
Old 01-13-2013, 04:54 PM
Navin Johnson
TimT's Avatar
No...
If the instrument is calibrated in free air, does the output span completely from 0-5 volts? I checked the free air voltage etc, and had to adjust the math to get the numbers to match..
The output of the WB sensor is a corrected a weird curve.... each Mfg of WB units writes there own functions,
Perhaps what the MS expects is not what is output from the WB controller is contributing..
'69 911 GT-5
'75 914 GT-3
and others
Old 01-13-2013, 05:20 PM
