930 differential output shaft - special length required
Hi all,
I'm in the final design stage of designing a Hayabusa powered open wheel hill climb (bitumen) car with a 930 LSD to take the torque. My question is "who makes special parts" like a 55 mm extended length stub shaft" ? Here is a pic of my proposal to show the layout. Cheers John |
A machine shop that specializes in gears should be set up to make splined shafts, some other general shops will possibly have the tooling.
87 930, |
Well above my pay grade but look for Matt Monson he could have a clue.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
gearhead
Why not just make a spacer to run between the flange and the CV, and run longer bolts? Why does it need to be at the gearbox side?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
California Motorsports dot net
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
