| Registered |
				930 engine noise
			Hello, I was looking for some input on to what your all think about this noise coming from what seems like the drive side engine area. https://imgur.com/a/moue5I6
				__________________ 1978 930. | ||
|  06-05-2022, 02:09 PM |
| Registered |
			Not good, obviously. I’d suspect a collapsed chain tensioner and be worried that the timing chain is slapping against the aluminum housing. Might want to sample the oil for aluminum if that’s the case.
				__________________ Ken 1986 930 2016 R1200RS | ||
|  06-05-2022, 03:25 PM |
| Registered |
The noise comes on about a minute or so after being started. It sounds like it's coming from the driver side. What's the best way to do an oil sample?
|  06-05-2022, 05:00 PM |
| Mighty Meatlocker Turbo Join Date: Apr 2016 Location: North TexASS
			I've listened to you vid several times, and if it were mine, I would remove the left/driver's side exhaust rocker's cover and check for a broken head stud - the compression blow-by from that often sounds like a mechanical noise similar to what is in your video.
|  06-05-2022, 05:13 PM |
| Registered | Quote:
|  06-05-2022, 05:36 PM |
| Registered Join Date: Jul 2011 Location: Marietta, GA
			I would try not to run it anymore until you figure it out.  I would definitely pull the valve covers and inspect as it is fairly easy to do... that will also net you some oil although probably not a quality sample to see about metal debris... I would just drain the oil from the motor... drain it onto a rag if you can as it makes it easier to see although sometimes you don't need it   It had a few strange noises going on but I would pull the valve covers first... if you don't see anything there I would say something has gone bad in the timing box... as mentioned by GSXRKen perhaps a collapsed tensioner or like the nut backed off the camshaft if that is even possible. If you do run it again I would use a long screwdriver as a stethescope and see if you can pinpoint the noise, or you can buy a car stethescope and feel around the motor until you can source the noise. Good luck buddy~ J
				__________________ John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! | ||
|  06-05-2022, 05:40 PM |
			Post doubled... delete.
				__________________ John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! Last edited by JJK78-951; 06-05-2022 at 05:42 PM.. Reason: Post doubled | ||
|  06-05-2022, 05:41 PM |
| Registered |
			Okay so when the car first starts up the noise is very low and it gradually get louder within two minutes. I checked around with a stethoscope and feel like the noise is definitely coming from what I think is the scavenge pump? Is where I have the stethoscope in this picture the scavenge pump?  Here is another video when the car first starts https://imgur.com/dNK0R5k
|  06-05-2022, 07:19 PM |
| Registered Join Date: Nov 2017 Location: Qatar
			I had almost the same noise, you can hear it in this clip : https://youtu.be/CeC9iYysiqg and this is what I found when I opened the driver side chain cover (I did not turn the engine in any direction when I switched it off, although it looks like it was turned the opposite direction) : https://youtu.be/OK7LV6gMDfY What I found was a small leak in the driver side oil feel line that prevents the tensioner from getting enough oil pressure, crimped a new hose in the line and issue was solved. I hope yours will as simple as that.
				__________________ -1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. | ||
|  06-06-2022, 09:46 PM |
| Registered Join Date: Oct 2006 Location: MYR S.C.
			when my tensioner collapsed on my 2.7 it sounded like a big exhaust leak.  it would get quiet at speed, yes i had to drive it 250 miles home. but made noise at idle. the tensioner does its job mainly when you let off the gas and at idle. the other thing i would do is pull the vlave covers and make sure you dont have a rocker working its way out. it really sounds like a tensioner though.
				__________________ 86 930 94kmiles [_  _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_  _] RUNNING: [__] NOT RUNNING: 01 suburban 330K:: [_  _] RUNNING: [__] NOT RUNNING: RACE CAR:: sold | ||
|  06-07-2022, 03:54 AM |
| Registered |  PO left the the smog pump pulley bolts loose.  The drive pin for the scavenge pump is still tight but one side shows a little wear. | ||
|  08-30-2022, 08:02 PM |
