Help Identifying Fuse
Went to take the 930 out for a nice Memeorial Day drive and of course battery was stone dead. I replaced the battery 2 weeks ago so I figured there was a draw and sure enough I found one. My car does not have a fuse block sheet on the cover so I would appreciate help identifying exactly what the fuse controls. I know it covers the radio for sure but what else? It is the4th fuse from the left under the fuel pump relays and a 5 amp fuse. Can anybody check their fuse cover and help me out My car is a 1989 Cab.
Thanks in advance
89 930 Cab Black 11 Cayenne |
Looks like Clock, Radio, Interior lights. I will try to scan the paper.
87 930, |
Not a great scan but here it is
87 930, |
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Thanks for the replies. Looking at the first scan it would be the clock, interior lights and radio but on the second scan it also lists AFR Guage. Is the second scan a factory diagram? Is that for a air fuel ratio gauge or something else?
If you have an AFR factory gauge that is where they would plug it in.
What you could do is individually pull wires from the fuse - to the individual bits. Put an ammeter across them and see what is drawing power with key off, and how much. Will it be enough to flatten the battery? Alan
Thanks Alan
