Thanks for the feedback, guys. I'll stick with my plan of having knock status/control.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
I will be running ECU Master Black on my 3.2 turbo conversion. I used the same ECU on my 95' Audi S6 that's running 30 psi of boost. It's a very versatile system and, yes, having knock detection is a big deal. My opinion is that Black is definitely worth it over the Classic. Also you will want to get the SD card data logging add on. VERY helpful when the car does something you didn't expect and you need to go back to diagnose.
For knock control, I've heard that the air cooled engines are so loud that the knock detection is of limited use. I'm still going to give it a try and will be installing the Porsche knock sensor bridge on each cylinder bank. |
Just bolt it to the block - pretty much the conventional location for most vehicles that came from the factory with one. On the transmission bellhousing works fine, per Jake Raby. This works for the same reason that you can (apparently) hear a train coming by listening to the rail, or whale songs are audible for an estimated 30-160 KMs underwater - thicker medium propagates sound better, which would dissipate much more rapidly in air.
'77 S with '78 930 power and a few other things. |
I'm using an Emu BLACK and have a single knock sensor mounted to the bottom of the throttle bellcrank on the top of the case.
Being very new to ecus and software, I'm not qualified to give any advice, but from what I've learned so far, you need to run the engine to record the normal range of frequencies produced when it isn't knocking and then set set the levels in your knock table to be higher than the recorded frequency. So that if the ecu detects a frequency higher than the levels you've set for your engine, it determines it as a knock event.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
The 964 used the knock bridge. I figured Porsche had their reasons so that’s why I opted to not bolt to the block. I don’t know how active the knock control was in the 964, but all manufacturers put serious time and $ into knock detection. Aftermarket ECUs that listen for a single (user defined) resonate frequency are very basic by comparison.
It’s possible that the block is the better place to mount the sensor for this engine. These kinds of things are rarely intuitive. Most OEMs mount to the block but up along the cylinder, typically near the top. The whole engine structure is pretty rigid so maybe the location isn’t that important In my Audi I added a third knock sensor that I ran to an audio amp and a headphone jack in the glove box. Actually listening to the engine is what many tuners do as the knock sound is unique and easy identified. Not louder…but more harsh. I also tuned the engine on E85 to get a good engine noise baseline that I knew was knock free. You then set an allowable noise level beyond that baseline across various rpm and manifold pressures. I set it very close to the base engine noise so I get false detection pretty often. I’d rather stay on the safe side and have it pull a couple degrees of timing every once in a while. |
Chain fence eating turbo
Getting Close!
Transmission re-gearing is done and will be picking up tomorrow.
Long block is also nearly done. Might be able to pick up as soon as the end of this week or early next week. It probably would've been done last week but we ran into a small snag with one of the oil control rings having a relatively small defect in it. (I could hardly see it until the builder pointed it out) We wisely opted to just get a new single piston set to replace. We don't want to create any hot spots along the ring. I'll add a pic of it later. ![]() ![]()
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 11-11-2024 at 09:12 AM.. |
Long block is back!
I got the long block back. Just in time for winter here in the PNW.
Now the fun begins. The plan is to basically get things up and running with my existing set-up: MSII, fuel-only. I'm installing/adding the Clewett CAM sensor, TPS sensor and a knock sensor as I'll eventually upgrade to the MS3PRO EVO and go for a full sequential setup with COP twin-plug ignition and fuel. That's the plan at least. I have a list of things I need to do before installing and the first start. May not be complete but it should keep me busy for awhile. ![]() I'm excited for the twin plug setup! However, I won't have it fully setup during the first phase of start-up and break in. ![]() One of the smaller side projects is to replace all the fuel lines pictured below and converting to -6AN fuel lines, plus a new Aeromotive FPR. Paul Mason is helping me with some connections to get me going. I also plan to use his fuel kit to replace the tunnel lines as well. ![]()
Some cosmetic progress.
Some cosmetic progress and a little camshaft drilling....
Mocking up a few pieces on the motor to see how things look and fit. ![]() ![]() Prepping the valve covers for paint. ![]() Moving forward on updating to modern AN fittings and PTFE lines. ![]() Some painting progress. ![]() Cam sensor done and installed. ![]()
Drive it like u stole it.
Kyle,
Where did you source the fuel rails from? Any info you have on these would be great. Bill
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
https://www.bitzracing.com/
Intercooler
Fitting the intercooler. Relocating from side intake to bottom...
Enjoying the build thread. It’s really looking nice. I’m sure you’re getting excited now.
912E-3.oh |
![]() I'm nearly ready to install in the car, but I have surgery scheduled tomorrow that will lay me up for a couple of weeks. Sometime in March though...
Nearly Ready for install.
Cleaning the engine bay to paint, but first starting to weld in some gussets on the shock towers for possible coil-overs in the future.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 02-20-2025 at 11:56 AM.. |
Turbonut
VEMS has had onboard dual WBO2 and dual knock for like 15 years, just sayin'..
Nice build!
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
Thanks! I'm already familiar with Megasquirt. I like the ease of tunability, and price is right there with the VEMS, which also includes the harnesses. MS has become a lot more robust over the last few years with lots of cool features without adding to the price. And like a lot of the high-end ECU's, the support is huge!
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 03-02-2025 at 04:54 PM.. |
Wiring Harnesses
While I recover from my hernia surgery, I figured I could get the sequential harnesses created, fitted and out of the way for when I'm ready to make the switch.
![]() Starting the Ignition Harness. Cylinder 1A and 1B (top and bottom) I'll cut and splice in the common ground and power once I have these all made. These connector pins are a PITA to build. ![]() Test fitting the top and bottom Ignition harness piece, with pass-thru hole cut in the engine tin to keep things neat. ![]() ![]() Injector Harness is complete. I'll dress it up later once it's been tested. ![]()
Getting close....
Getting close to first start....
Electrical test and check = Good Fuel test, pressure adjustment = Good Oil and engine prime coming up next.... ![]() ECU configured for slightly increased displacement (3.0 --> 3.2), VE Table increased 6.6% to compensate for the increased air. Injector FuelReq adjusted from 444lb to 60lb = Done ![]() New Stack gauges installed (Fuel Press, Voltmeter and Boost) Fuel/Volt = Good Shifter tunnel raised. Adjusted and shifts good as it sits. Interior will get some paint to cover fresh welds to the lowered seat rails and shifter tunnel. ![]() Will do oil prime/starter test (installed a new WOSP starter) before installing and finalizing position of intercooler. ![]() Nervous wreck before starting... check.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs Last edited by flat6pilot; 06-18-2025 at 12:06 PM.. |
