🌀 Quick Boost Spike Fix on My 930 — Simple Solution
Was getting random boost spikes on my ‘86 930 — thought it was the WG spring or overboost switch.
Turned out to be a cracked vacuum line to the wastegate! Replaced it with high-temp silicone hose, and now boost holds steady at 0.8 bar.
Old school fix, but worth checking if you’re chasing boost weirdness.
Anyone else dealt with this?
Old 07-24-2025, 11:28 AM
908/930's Avatar
Just checking that the silicone hose you used is a reinforced type? That hose also required to hold pressure.
Old 07-24-2025, 12:19 PM
mark houghton's Avatar
Good deal! But to be clear, the hose to the WG is not under vacuum...it's pressure. And the over-boost switch/sensor will not cause an over-boost scenario should if fail. Designed to cut off your fuel pumps in the event of over boosting due to a faulty wastegate (or plumbing to it as you have found).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-24-2025, 03:22 PM
