🌀 Quick Boost Spike Fix on My 930 Simple Solution
Was getting random boost spikes on my 86 930 thought it was the WG spring or overboost switch.
Turned out to be a cracked vacuum line to the wastegate! Replaced it with high-temp silicone hose, and now boost holds steady at 0.8 bar. Old school fix, but worth checking if youre chasing boost weirdness. Anyone else dealt with this? |
Just checking that the silicone hose you used is a reinforced type? That hose also required to hold pressure.
87 930, |
Good deal! But to be clear, the hose to the WG is not under vacuum...it's pressure. And the over-boost switch/sensor will not cause an over-boost scenario should if fail. Designed to cut off your fuel pumps in the event of over boosting due to a faulty wastegate (or plumbing to it as you have found).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Thread Tools | |
Rate This Thread | |
