how to reduce popping during deceleration
finally ironing out my fuel issues with the 3.0l row turbo runs and pulls great . i would love to reduce the deceleration popping sound. first i probably need to understand what causes that sound and hopefully there is a way to reduce it .
in a nut shell my 3.0l built to stock with stock P&C evergreen raptor mod k27 turbo long neck intercooler original Vacuum Limiter and a 964 bov fully adjustable wur. and a boost enrichment hold out controller currently set to 4800 rpms. i believe i have my wur tweaked correctly i have good afr # idle about 14 with a nice afr curve that runs to mid 12s just before boost low boost high 11s and full boost low 11s. When i let off the gas the afr# jump into the upper 14s low 15s. when under a load when i let off the gas i get the popping without a load i just get gurgling. on a side note the car is a row but i have the timing set to American settings 5 deg advanced and 22 retarded. The row settings are tdc and 26deg retarded . i have not played with the setting other than at an idle and i didn't notice a difference. would this help with the popping ? i would love to learn more about the popping and the variance in the timing between the row and the American. .. Thanks in advance Regards Ned |
Pretty sure the popping is just unburnt fuel igniting in the exhaust, EFI sends in no fuel when you let off throttle where CIS still allows fuel in. What muffler is on the car?
87 930, |
You want to do a few things to reduce popping the biggest is probably some sort of fuel reduction or cutoff.
what ecu are you using? tuner studio has a setting for it I know. You can also advance the ignition so that any fuel that is burning has a long time to burn before hitting the exhaust. I know guys who like that noise will often retard the ignition significantly to spark it off late.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
The only way you're going to get rid of it is going EFI with an overrun fuel cutoff.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
1976 930 Running csi pre ECU old school .. I have a friend with a 77 similar set up not nearly as much popping.
My 76 also has a lot of popping on deceleration. I have a later exhaust where the wastegate does not dump into the exhaust. I always thought this was the reason, but seems not to be.
Crotchety Old Bastard
Push in the clutch.
Popping on decel is a function of the CIS combined with freer flowing muffler. The C in CIS stands for Continuous, the injectors will continue to flow as long as the air metering plate is raised. If you allow your engine to engine brake by not clutching during decel the extra unburned fuel will ignite in the muffler. If the muffler is free flowing you will hear the explosions. Stock mufflers mute this with all the packing, baffles and catalytic converter on those cars so equipped. The idle bypass valve helps mitigate this phenomenon, the burbling becomes more pronounce if that valve is defective or removed.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
newbie question is the idle by-pass the same thing as the bov? Also could a semi rich idle mixture add to this popping and and gurgling? i set my idle mixture by Backing off about a 1/8 turn from the injector squeal. A few times, when i trigger the fuel pumps from the engine bay while setting up the wur i could hear a few quick injector squeals. for a seconds then they stop. Last edited by gorskined; 02-26-2024 at 04:28 AM.. |
Mine is converted to EFI and I miss the pop sound!
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
I did too, so i turned off the overrun fuel cut and added a little fuel and pulled some timing in the higher rpm, high vacuum cells. Now it sounds like it did before.
Perhaps an unpopular opinion but the popping is part of the appeal for me. It's old, it's raw...just like it should be
'81 924 Turbo (931) '87 944 Turbo (951) '84 911 Turbo (930)Flachbau '89 928 S4 '04 911 Turbo (996) '08 Cayenne Turbo (957) |
I used to like it until it became a fad and all the tuners, With their cambered Honda's started purposely doing it . Now every spring the stop signs around here sound like a war zone.The good thing it is usually short lived. The cars would be broken down and back in the garage in a month or two. ![]() |
My CIS 930/60 would make a lot of burble, pop, blat-blat-blat noises on the overrun, together with some infrequent (and sometimes pretty loud) backfires.
Par for the course for a CIS car, I believe. But it can be a little awkward when you've got a noisy exhaust and are trying to be inconspicuous in town.... I found that giving it just the tiniest touch of throttle on the overrun - like, literally, just off the stop - would greatly reduce popping/burbling. Apart from any other considerations/opinions, coasting in neutral is illegal many places.
'77 S with '78 930 power and a few other things. |
Ingenieur
The zinc plated vacuum limiter is supposed to eliminate the popping. Is the vacuum control line connected correctly? If it is original, the diaphragm has likely degraded and made it non-functional. It is testable with a little effort. The other possibility is that it is just too rich under load to compensate as adjusted.
Thread Tools | |
Rate This Thread | |
