Exactly what i was thinking .. not sure .
Was thinking of 2 fans on the engine lid grill or .. |
Great minds think alike.
don't mess with electric fans. Your mechanical engine fan will move WAY more air - try ducting.
also try methanol injection- the methanol/water mix will lower your intake temps after your inter cooler (I have several kits from Devils own methanol injection) inject after the intercooler. methanol/water mix will also increase the octane of your Gasoline. one more trick is to add an extra nozzle to spray methanol/water on the outside of your intercooler one final trick- IF - you have a really modified engine and you are using really big nozzles - you need to add some oil to your methanol/water mix so it does not wash down your cylinder's I use Kolts racing castor oil ' BeNOL' it is refined and de-gummed. (you can do this for regular installations just for the smell) I have had several boosted motors on this and when I tear them down - NO gum build up , no nothing the inside looks clean....and no smoke you just add a little. And the biggest befit - when on the boost it smells like Castor oil and I get thumbs up from the sport bike guys or anyone who I pass or is following me. |
Yeah, methanol injection would be great.
I used an intercooler about 2x that size at .7 and feel safe, but I have a 3.8 tail. I agree that the electric fans would be of little benefit unless they were radiator sized, and those would be a rough fit.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Why does it seem like it's very simple to boost these engines..?
I should not be considering it but it's hard not to!!
Mario L - Cleveland OH IG & YT @SuperishMario Current - 1977 911S Widebody Project, 1982 911SC Targa Sold - Lost track |
Dieter, this video is interesting.. not a porsche but they fitted a top mount. At first they tried a fan but said it made little difference. In the below vid they dyno run and now have a shroud that guides the flow of air through the bonnet and through the cooler. And worked much better than the fan. Discussing effects on air temp after fitting shroud https://youtu.be/M8QTHdoNHDw?si=NyUZUJqud6TBF5xM&t=350 full video here.. you can see the rubber shroud they made... https://youtu.be/M8QTHdoNHDw?si=gk-g33U3JJXmL1SQ
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Cliff
Can you talk more about the ecu? What exactly did you do there? Also did you not add a fuel pressure regulator?
Also have you considered a maf conversion? Thanks |
Talk to raceboy if you wanna know more .. Vems regulates fuel.. no need for a regulator. If you keep stock ecu then you def need one . This is the kit i used : https://www.pnpecu.com/vems-porsche-911-32-carrera-32-231-hp-64-p.asp I got the stealth one .. it looks like a stock ecu because it uses a normal bosch shell . |
Cliff
Awesome. Thanks this is exactly what I'm looking for. Where do the additional sensors go? Temp and map?
Turbonut
MAP is built into ECU, you only need to run vacuum line from intake (tee it from FPR vacuum line) to ECU.
Intake temp sensor comes with the kit and uses short adapter cable that allows to plug it to AFM engine side plug (AFM is not needed). Kit also includes WBO2 sensor wnd wiring and proper throttle position sensor with special adapter cable (that converts 3pin female JPT plug from TPS to one male JPT 2pin and male 3pin JPT plug) so that cutting of factory engine harness is not needed and everything is easily reversed to stock if needed.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
Cliff
Hey again,
Can you explain a little more on the oil feed and drain setup. I see the turbokraft feed line, but you mentioned a 930 to block adapter, I'm not familiar. And on the drain side, do you see a need for an accumulator? And finally where did you terminate the oil drain tube at? Thanks for your time. Trying to wrap my head around everything I need. |
This is an amazing build. Nice work! How’s it running?
That seems like a very big turbo for the boost you are running. I’d guess boost will come on later but it will run very efficiently up top. |
Turbonut
Boost level has nothing to do with turbo size, turbo is chosen according to engine displacement, compression ratio, rpm range etc.
Air cooled 911 engine cannot be paired with small turbo, it creates huge backpressure and anemic powerband (=like diesel engine), not to mention most important thing, knock treshold will be very soon btd.
It reduces the dimension for the oil feed line on the block . If you use the oil feed kit from turbokraft you need this, on the 3.2 that is, dont know for other engines . The oil drain gravity feeds to my oil drain plug in the sump.. no need for accumulator .. oil pump sucks it back into the engine . Please ask if you have questions .. |
The boost comes quick at about 3k rpm .. |
Interesting project, what's the compression ratio? and what cam?
Keep us updated how this works out and what max boost level you finally decide on.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Thank you, i have not messed with compression or cams .. all original us model 3.2 engine spec . Boost about 7-8 psi . Drives like a dream and turbo noise is adictive |
Thread Tools | |
Rate This Thread | |
