E-85 sippin drunk
turbobrat930's Avatar
Hello fellow boost pipe addicts!!
Its been a LONG time since I was last on here!! Some of you I have met in person over the last few years. Just checking in to say hi Still have the carbon 930 with the polished engine. I have over 70k miles on the build, and still going strong.
Hope all is well with you gear heads!!!!
Brad
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-20-2024, 04:56 PM
kevinbodman930's Avatar
It has been a while.You have one of my favorite 930s.I am glad she is still hauling ass to me its one of the best modded turbos
that I have seen.
Sent from my SM-F946U using Tapatalk
Old 03-21-2024, 06:37 AM
Brad, great to hear that you are at 70,000 miles and still running strong!
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 03-21-2024, 10:14 AM
Banned
DEWDIUS
great to have ya back here
in the meantime we've managed to run the Blue Ridge Ruckus & Targa Carolina together, and host you here coupla weeks ago to mend mah oil leak 8 )
here's to lookn fwd to our next adventure together muuffuukkaahh!!
ps. having been one of the quiiiiite veryfew Brad's let drive BOB (Bucket Of Bolts), I can attest that @ 2150lbs and 600hp it's abbbbbbbbsurrrrrrrrrrrrrrrrrrdly ridiculously FAST (my car F*CKS... Brad's car f*cks HARRRRRRRRRD...
Old 03-21-2024, 01:22 PM
Crotchety Old Bastard
RarlyL8's Avatar
Hey Brad you need to post some pics of the beast so we can see what all you've done the last few years. Awesome that you're racking up the miles of smiles! What all is left that needs to be swapped over to carbon? I've got a guy making just about every part imaginable for these cars in CF. Just finished molding the upright on the tail, it weighs one pound!
Old 03-23-2024, 06:46 AM
E-85 sippin drunk
Kevin, Rahl, Paul, and Brian DUDES, great to hear from you. Well, Paul and I chat every week, but it is good to reconnect.
The car has had the clutch replaced, as it did not hold the HP ( I had the RUF BTR yellowbird clutch). Called Chris at TK up, and we ended up going with what I have been told, is the highest clamping force PP that Sachs makes. It is the 934/935 stuff. It is holding for now, but the only upgrade now, is to the full race puck SOLID center disc, which will be NO Bueno for street use. But its holding for now.
I also ended up getting rid of my Clewett cam sensor ( on the end of cyl #6 cam tower) and going with the Rasant version, which plugs in the distributor hole, A MUCH improved setup. During this, I also removed the M&W CDI box, the Bosch coilpacks, and Magnacore wires, and went to full CoP. They are Denso coils, and for the 12, they were right about 1k. Then went to ProWire USA , and went to Tezfel wire, Reychem heat shrink, and Deutsch connectors. I built my own harness for the 12 CoP, and got it all installed. I think that was the single best upgrade I did to my car! They are phenomenal!!
I also rebuilt my ENTIRE steering collum, and also replaced the ENTIRE from suspension pan. Now that was a TON of work. I will make a separate post on both of these endeavors.
I think I also made a post years back, where i took off my GT35r ( TiAL version), as it killed itself... the ceramic ball bearings went tits up. I now have the Garrett GTX3584RS with a 1.02 A/R turbine housing. OMG, this turbo is F@$$@&!! AMAZING!!!!!
I have been on several trips with the car, and numerous rallys, mountain runs, and shows.
Brian, I have the doors, front fenders, hood, front bumper cap, and rear tail all in Carbon Fiber. Those parts are 25 years old!!!! and still holding up. I am looking to get some real flares in carbon, and cutting the steal ones off.
Here are a few pics throughout the last few years.
Old 03-24-2024, 11:39 AM
Always loved your car Brad.
Killer..every detail.
Very inspiring.
Old 03-24-2024, 06:37 PM
ahenthus's Avatar
Magnus looks suitably impressed.
Old 03-26-2024, 03:06 PM
RarlyL8's Avatar
We're finishing up on a rear bumper in CF now and will be doing a replacement sunroof, rear quarters and several other areas. How about a set of brake shields in carbon?
Old 03-27-2024, 08:01 AM
E-85 sippin drunk
Brian, Looking good!! I am looking for a set of rear quarter panels in carbon. They must be full carbon fiber, and need to look like the quality of the part you posted. Stock 930 flare width is fine ( oversize is ok as well, but then I will have to get bigger outer lips for my wheels, and spend way more $$$$ on the rear tires...) I am talking the whole entire rear quarter from the rear edge of the door, just below the rear quarter window, all the way to the rear lights. I will epoxy them on.
Brad
Old 04-05-2024, 11:32 AM
mark houghton's Avatar
Yo' Bard...only hear from you on FB anymore. I'm guilty of the same, don't hang out enough on Pelican as I used to. There was a period when I lived here! Good to touch base once in a while...see what's new or what wisdom we can share.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 04-08-2024, 02:52 PM
RarlyL8's Avatar
Yes we will be producing the 930 rear quarter panels (the test bed for this line is a 930). Do not know about timing on that just yet. Eventually every panel and a bunch of parts will be done in CF/Kevlar. None are laminate, all are 100% CF/K.
Old 04-09-2024, 03:08 PM
RarlyL8's Avatar
Here's a pic of the turbo tail base.
Old 04-09-2024, 03:13 PM
That's beautiful.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-09-2024, 04:56 PM
E-85 sippin drunk
Absolutely Mark!! FB land is getting to me... I needed to get back on here and catch up with all the 930 guys!! Will definitely be on here more!!
Old 04-09-2024, 06:31 PM
E-85 sippin drunk
Very Nice!! Yea, put me down for the first set of rear quarters!!! Let me know when you start on them!
Old 04-09-2024, 06:32 PM
RarlyL8's Avatar
Working on an all carbon 911SC now, will get back to the 930 soon. Street car with full leather interior carbon accents and sound deadening. Will be interesting to see the final weight and front to rear ratio. Your 930 is similar in composition if not a bit more hard core.
Old 04-11-2024, 12:54 PM
