930 clone restore - if you had it to do all over?
as I get close to finishing my 951, starting to think more serious about this project.
so .... been reading a lot of threads here, probably too many, and seen a lot of incredible builds. IF YOU HAD IT TO DO ALL OVER, WHAT WOULD YOU DO? hoping for posts or links to other threads with ideas. I keep seeing post of what people would do different if they had the chance. hope to get ideas from those who have gone before me. just a short intro for now, and more pics to follow soon. I stumbled on a 78 930 clone, built on a 78 SC in the 1989 - 1990 time frame. got it almost a year ago, just could not pass it up. took some crap from my wife about it, as it made the 5th P car I had at the time. just finishing the resurrection of an 87 944S for my bro-in-law, and had not even started work on the 951 DE/street build. pic of PO. ![]() I got the car not running. the muffler case split and the hot exhaust burned some wiring and stuff causing it to quit. guy I got it from said it was running great, just scary has hell to give it much gas. ![]() ![]() ![]() guy who had it built had a 78 3.3 rebuilt from the crank up, modified, head work, twin plug, etc. have a lot of pics and records. not totally sure what all was done, need to sift through the records more closely. he also had the 915 tranny rebuilt, including a taller 5th gear. again, need to dig into the records to see what was done. saw the record of the clutch, dont recall what was installed but it is really heavy pedal feel. was told it dyno'ed over 400hp. had the SC body stripped down, sand blasted, steel rear flares and the slope nose fenders added, then full paint. hard to guess what the guy spent building. I suspect for equal or less $$ could have bought a factory 930 at the time. but also guess not what he wanted. unfortunately, has some significant paint cracking around the rear flares where welded and in a few other spots. so will probably repaint, but not sure I like the current color. may change color, and if I do want to research the factory colors for 78 before I dedide. another question in my mind is trying to have someone rebuild repair the damage to the extened whale tale. cut out the damage and replace with a screen, or get another tail. (I have the rubber edge, in good shape) ![]() ![]() ![]() the guy left it on stock SC suspension and brakes. already decided I want to go full 930 brakes. don't think I want to go floating hubs / rotors, but may as that was factory for 78-79. just starting to consider what to do upgrading the suspension. when I got it, partially dropped the engine, cleaned up and repainted the engine tins, misc stuff, and fixing the wiring. then stopped and decided it was going to get a 'full monty'. always lusted for a 930, I have a pic of one on my office wall to my left. as the values of 930s are going way out of my budget, never thought I'd ever have one. so want to do a total and thorough job of it. so returned to finish the 951 project first. until the next installment, start giving me ideas to pursue.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
DP935 member
Looks like a nice project. I have a factory turbo tail base that I am selling for $275 plus shipping if interested. I just sold the rubber to another Pelican.
Not sure if you are interested but thought I would mention it. The tail you have looks like a DP type extended tail. Somebody can probably fix it for you but not sure how much they would charge.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
I am planning on fixing that whaletail. if I cannot find someone with the fiberglass-craft that can make a mold to make replacement sections, may cut it out and fab a wire mess screen. I considered buying a used tail and cut out this section and graft, but it seems the form / size of this section on this tail is different than a stock tail. but whatever I do it will need to look GOOD.
stumbled across a nice set of 78-79 long fin calipers, could not pass up. now off to the shop to continue installing the new clutch in the 951. ![]()
I'll have to look at my calipers. They seem to be the same on my 82 930.
thanks, have not researched the part #. just went by what the guy from whom I got them saying they came off a 79 with floating hubs/rotors.
my clone is built on a 78 SC. I picked these up due to discussion with Steve Weiner at Rennsport systems. he has made adapter kits for 930 calipers to fit to SC.
finally getting restarted on this project.
so I will repeat the title of this thread. if you had it to do all over again? over the past year I have been reading lots of threads on this forum. now I may have too many ideas and not enough $$$. when I got the car I initially thought I'd repair the wiring and get it running. but then notice things like old fuel lines, etc., and came to the decision I was going to do a full refresh. and if I am, will tear down the engine and tranny and rebuild anything needed. just dont want to put a lot of time and $$ into it only to find issues with the engine/tranny. so I will have some time to finalize the reassembly plans and what I will do. one major consideration is the ignition. has twin plug but old electromotive ign, so plan to upgrade to something more modern. so far I am planning to retain the CIS. if I end up with 400+ hp I will be happy. a couple of pics of the current state. been looking forward to this project for over a year. but my 951 DE build and some maintenance on my other Porsches kept getting in the way. I look forward to idea, suggestions, warning, and advice from this distinguished crowd that will help ensure I end up with a great 930. ![]() ![]() and some inspiration hanging on the wall in front of it.
Bob, welcome to the forum. You've got a project on your hands for sure, but based on your signature list and previous projects, you sound like you're up to it.
I'd suggest that rather than tear into engine in exploratory mode that you warm it up and perform a leak down test on it to get a sense of overall top-end health. Then pull it and store it out of the way. You can enjoy an otherwise safe and very well restored car with a slightly smoky, slightly leaky engine/trans. Drivetrain work can be done at any time, when the budget funds have recovered from the paint/body stuff. (Except for the blue and yellow bits in the engine compartment. They have to go asap as they are horrendous) Looking forward to another build thread here instead of another wanker value thread. Stay on it and keep us posted!
Ken 1986 930 2016 R1200RS |
gsxrken,
thanks for the encouragement. initially I had started to just sort out and repair the burned wiring. but then encountered cracked fuel lines, and when checking both fuel pumps were not correct. and yes, the blue/yellow and red you cannot see will disappear. on my other cars I have done some limited and think tasteful engine part painting. but this is pretty hideous. once I blast off the ugly, plan to just keep this engine unpainted. let the clean alum show. at first I was not sure, but have decided to build this for DE/track and street since it is a clone. so no worries about 'value'. value to me is the fun of DRIVING THE WHEELS OFF OF IT. so no scrimping on the mechanicals. also heavily leaning toward doing a G50 conversion. since this only saw street driving, the 915 has survived so far. but wont for long on the track. the one compromise in my total plan is to rebuild the engine and upgrade the tranny, and do the body/paint work. and get it running. then will attack a full suspension upgrade as phase II. yea, the more I think and plan, the more $$$$ it will cost. but then, I hope to fully build this bad boy for less than the cost of a new cayman. so need to get more serious about selling my 928S and motorcycle. then as this comes together, I can sell the 951. or maybe I won the lottery yesterday, need to check. started working on dropping the engine/tranny last weekend, but now also need to replace the lower ball joints and bushings on the 951 before the next DE. so I should start having something interesting to post soon.
here is something to consider.
when i was looking for a 930 i looked at an AWESOME twin turbo 77 911s. but that was all it was ever going to be. a 77s with a twin turbo. the option i was considering was rebuilding my 77 with a nice 3.0. i dont know how much you plan to put into the car but you might want to consider what you could get if you sold what you have and added that to the money you plan to put into this car. who knows, you find a nice 930 now, drive it for 5 yrs and sell it for more than you paid for it. your car is an interesting looking project. if you plan on keeping it another option is to sell the engine and find a really nice 3.6. lighten up the car and you will have a really fun car to drive. do a compression test on it and see what you have.
thanks for the thoughts.
but part of my love of these cars is wrenching. 4 projects now on the road and this will be my 5th. what I hope to end up with is a fully refreshed beast of a 930 that can handle DE/track time and accommodate occasional street driving. I am bracing my self for a budget of $50k to build this car to what I want. my suspicion in today's 930 market is any 930 I could afford to buy would need a lot of work to bring to the level I plan for this. until I get this built, I have my 86 944 turbo for the track and just drove my 85 911 targa yesterday. may need to get the 928 back out due to the heat here, as it has cold AC.
Build what you want and drive the wheels off of it.
People might not like the fact that I "cut up" a rare car. But I enjoyed the journey and enjoy driving it even more. Stick with it brother!! |
Bob, your car kinda makes me chuckle when I see it.. cause its very similar in looks to my 930
as in, Petrol Blue Slant nose w/DP extended tail!
RGruppe #180 So many cars.. so little time!! |
Merlin,
you are one of my inspirations on this forum. in my case, not a rare, factory 930. as said, value to me is the driving experience. I had hoped to come for the turbopalooza, but too much conflict in my schedule. hope you'all had a great weekend. need to catch up on that thread. I am still struggling back and forth over what tranny to use. I have accepted the existing 915 wont survive long for what I plan ... Bwuahahahahahah. I am leaning toward a G50, but need to check and see if I can find a local shop that can properly replace the torsion tube. onboost. glad you got a chuckle. I really hope I can find a good FG guy who can repair the heat damage to my tail.
so finally getting serious. hope to have frequent posts as I tear into this project.
finally decided on a 930 4sp. just got one, sending to Steve Weiner at Rennsport systems to go through, rebuild as necessary, regear, and add LSD.
before I seriously dig into this project, decided to clean out the shop and build a big shelf to put tires,etc on and get stuff off the floor and out of my way. 10' across so I can get around it when working on the car.
about to go back up on jack stands. now if I can just get that dang tranny off the motor so I can get it on the engine stand. ![]()
Banned
nice - good idea
great to see your progress on tearing into this finally, as well as to the 930box score looking forward to yer updates |
need to clean the dust off the poor thing from cleaning the shop. I had it rolled outside and we blew the dust out the door and most seems to have settled on it.
more progress. back up on jack stands. pulled the engine bay wiring harness loose and decided to pull the whole thing and replace. too many of the connectors are a bit crispy from the hot exhaust damage.
also got the rear fuel lines all pulled, ready to replace by the new ones made by Len Cummings. almost got the gas tank out, then drop the steering rack to pull the new tunnel fuel lines and install the new front fuel lines also built by Len. coming to the conclusion my tranny is stuck in the pilot bearing. so just keep jerking away, there were three of us trying the last time. (now I cant imagine what Ronnie would say to THAT). so until I get the engine on the stand, keep tearing stuff off the car.
Did you release the throwout bearing? Gotta do that before it will come off.
