-   -   Building a 3.2 short stroke (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1159964-building-3-2-short-stroke.html)
KRLocke 04-18-2024 03:34 PM
Cool motor build, what kind of hp do you think you'll get?
gsmith660 04-18-2024 03:44 PM
Going to limit Hp to around 350 until I can get my hands on a G50 the limit I have heard for a 915 then what I have seen is 400-450 for this build
KRLocke 04-18-2024 05:44 PM
Looking forward to following your build.
gsmith660 04-18-2024 05:47 PM
gsmith660 04-18-2024 05:49 PM
I certainly didnt plan on doing this right now and probably wouldnt have until I found out how scarce 3 liters are becoming
KRLocke 04-20-2024 05:48 AM
A lot of things have become scarce and if not are priced astronomically. 3.2s are best example. What used to be a $6500 motor is now a base price of $15K for one probably needing work. Rebuilt 3.3s are $35K which seems like a bargain, if they were done right.
gsmith660 04-24-2024 05:27 AM
You are absolutely right the motor I have appears to be in great shape internally but externally it had many corrosion issues that I believe we have arrested so it can now be stored until assembly which hopefully is not too far off
gsmith660 05-06-2024 08:59 AM
Today I pressure test the external oil cooler and hoses looking for the leak that killed my motor havent found it yet
flat6pilot 05-06-2024 10:48 AM
Originally Posted by gsmith660 (Post 12229982)
Did that require case mods other than removing the .8 mm squirrels and installing 1.2 mm?
I heard you may need to remove some webbing to fit the 964 pump, but mine didn't. They installed and closed the case on it to check clearance and it was ok.
gsmith660 05-06-2024 11:35 AM
Thank you
gsmith660 05-06-2024 11:37 AM
Pressure test was good 90 psi for 30 min so that is not the source of the leak
gsmith660 05-23-2024 07:35 AM
Not much to report the motor is still at the machine shop. I have been running new 1/2 inch hard fuel lines through the tunnel and cleaning up the engine bay. Gonna work on these small projects until I get the motor back.
gsmith660 05-23-2024 07:41 AM
http://forums.pelicanparts.com/uploa...1716478821.jpg
http://forums.pelicanparts.com/uploa...1716478829.jpg
KRLocke 05-23-2024 02:54 PM
Little things like a clean engine bay make a huge difference enjoying the whole process
gsmith660 05-31-2024 05:14 PM
http://forums.pelicanparts.com/uploa...1717204281.jpg
While I wait on motor stuff taking care of while I am there stuff.
gsmith660 06-13-2024 02:26 PM
Got the fuel system restored. Replaced the tie rod ends in the nick of time one was about fail.
gsmith660 06-13-2024 02:32 PM
http://forums.pelicanparts.com/uploa...1718317857.jpg
Installed new motor mounts
gsmith660 06-15-2024 10:53 AM
http://forums.pelicanparts.com/uploa...1718477168.jpg
Things to keep me busy while I wait. New bushings in the pedal assembly it is tight now, clean the carpets, reinstall the oil cooler and lines after cleaning and flushing, continue cleaning and refurbishing the engine bay. Things completed changed the oil in the tranny renewed throttle bushing on same cleaned and renewed the tranny mounts and general cleaning and preservation of the whole car.
ToySnakePMC 06-15-2024 04:49 PM
This is entertaining. You certainly have had this car for a while. Best of luck on the rebuild / turbo project. Patrick
gsmith660 06-15-2024 07:50 PM
Bought the rolling chassis in 83 with 8000 miles on it according to title paperwork this is the 4th version of this car I just like to have fun with it.
