Happiest when Tinkering
gsmith660's Avatar
Phase 2 of my build in progress
So phase 2 of my project is to adapt a stronger transmission into the car. I have decided to use a 996 6 speed trans using Top Designs adapter kit. So far I am in the parts acquisition part and I have the trans and the adapter kit from Tyler
also the brain to adapt an electronic speedo to an older mechanical speedo car
Working out details to get 108mm CV joints into my car since I have SC 100mm CV and my conclusion is a 74 axle will do the trick I just have to remove the 2 pins in each joint.
Next will be the coilover upgrade and I am working at getting my head around the chassis mods I will need to do. Initially it will be slow going not much will be done this winter as I want to have the majority of the parts on hand before I drop the drivetrain to start doing the mods. So please bear with me for now.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-08-2025, 08:30 PM
gsmith660's Avatar
So a little background I have a 78 SC chassis with a 3.2 short stroke built off of a 79 SC 3L donor engine so I have some interesting challenges here to get this shoehorned in so it should be interesting
Old 11-08-2025, 08:45 PM
Ryan_Cunningham's Avatar
Can't wait to follow along on this journey. I'm nearly complete on a 3.6 VRam swap in my '81 and this would be the next logical upgrade to replace the 915. It'll probably be several years before I attempt it but this is exciting.
"Purists are the Karens of motorsports.
IG - Iron_Dad_Moto
1972 Porsche 911 - Long Term Project. 3.6TT/G96.50
1981 Porsche 911SC - In Progress.
F/A-18C/D, F-15C, F-35B/C
Old 11-09-2025, 07:49 AM
gsmith660's Avatar
Follow along because having an 81 you would have many of the same challenges I will have
Old 11-09-2025, 08:04 AM
I have no idea how hard or expensive this is to accomplish, but I’ll be jealous when you’re done. The one thing that shows the age (or the era) of the 930s is the slow deliberate shifting that they require, regardless of Wevo/Stomski/delrin/new synchros… they will never be “snick-snick” like modern sports cars. To say nothing of the RPM drops inherent with only 4 gears.
Ken
1986 930 2016 R1200RS
Old 11-09-2025, 10:59 AM
gsmith660's Avatar
This shifter is cable driven and from playing with the shift lever it is very easy and smooth to shift gears this clutch is supposed to be really smooth and easier to depress than the stock so the driving experience will greatly improve I do have to say that the 915 I got in there now is adjusted spot on and is shifting better than it ever has not that I want to I can actually speed shift
Old 11-09-2025, 11:36 AM
Chain fence eating turbo
Those transmissions are pretty stout from what I’ve read but I know fitting them and spring have some challenges.
Way cheaper than a G50 box
Old 11-09-2025, 12:29 PM
gsmith660's Avatar
The prime mover on deciding which way to go G50s are outrageous now thanks to singer pedal assemblies are outrageous also due to singer G50 components are hard to find. The G96 is easier to find and apparently easy to work on and a 6 speed to boot but this is going to take a lot mare work to get it in. Thank goodness my carpet set was getting a bit worn in areas because the tunnel area will get a lot of attention. I should be able to keep my 993 rear seats but might take a bit of massaging.
Old 11-09-2025, 12:40 PM
HEY! Those are some nice looking parts! :P
Glad everything arrived safely.
We have a growing group of builders going down this path using my kit. With the collaboration that's already building, things will just get easier for everyone.
I've had a lot of recent interest on this kit. 2nd batch of adapting parts is in production now. Some additional parts to make the job easier are also in the works!
gsmith660 - It's be great talking with you as you start this project. Thank you for taking the initiative to start this thread.
Anyone who is interested or just curious about how this all works, feel free to post here or PM me, or get my contacts from my website.
More to come.
North Idaho CDA / Spokane area
Instagram: to.performance
MoTeC USA Authorized Dealer
Porsche 959 Department Manager at Canepa *retired after 10 years*
Website / Webstore https://www.topperformancetuning.com/
Old 11-09-2025, 09:04 PM
gsmith660's Avatar
Well it has been decided that I will adapt a 996 center console into the car because a lot of the stuff runs on top of the tunnel
Old 11-10-2025, 06:43 PM
gsmith660's Avatar
The upgrades to megasquirt are on the way MS3X daughterboard relay board and a MS3X wire harness are all on the way the goal is full sequential fuel injection COP ignition as well
Old 11-11-2025, 07:54 PM
gsmith660's Avatar
Big shout out to Aase sales they just gave me a killer deal on 2 complete half shafts (new) and the stub shafts getting all the parts together I am starting to realize this project is gonna be bigger than the engine project
Old 11-12-2025, 09:08 AM
Subscribed and good luck , we will be watching with envy !!
Old 11-13-2025, 06:03 AM
gsmith660's Avatar
Parts are starting to arrive!
Old 11-13-2025, 08:00 AM
gsmith660's Avatar
PARTS! and the trans is probably as clean as its gonna get time to crack it open and see what I got
Old 11-14-2025, 11:43 AM
gsmith660's Avatar
So this trans has no provision for the stock hardlline throttle so I need to get a measurement an find a cable that will go to the back and now basically none of the stock pedals are needed so I think I am going with a Wilwood pedal assembly and am researching what I need for master cylinders as I determine this stuff I will post what I use probably 23 mm or 27 mm for the brakes and 22 for the clutch about 1.5 inch stroke if this sounds right please let me know your opinions
Old 11-14-2025, 03:21 PM
You might want to cross post this on the 911 Technical forum for a wider audience. Someone has probably done the Wilwood thing and figured that out. The turbo board is the same 50 or so knuckleheads, and I use the term fondly.
Ken
Old 11-14-2025, 03:53 PM
Watching
Old 11-14-2025, 04:00 PM
gsmith660's Avatar
I am into a second gear replacement
Old 11-15-2025, 05:27 AM
gsmith660's Avatar
The inside of the case is really clean minor buildup on the magnet no sludge anywhere in the case so I am confident the only issue is second gear
Old 11-15-2025, 06:18 AM
