Me like track days
Craig 930 RS's Avatar
RUF intercooler re-do, clean up and replumb project
1) Glass bead blasted the RUF intercooler - took 1.5 hrs - P21S wax on top
2) Cleaned up wiring for the RPM full boost enrichment delay switch
3) Adjusted the WUR to lower the warm control pressure for a bit more rich in the midrange
4) NAPA has a silicone paste which is ideal for sealing the IC rings
5) Rerouted/replumbed the 'IC in' temp sender from the air cleaner to the IC inlet
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-31-2007, 02:42 PM
Me like track days
She-it.......hang on, pics aren't working........
Old 05-31-2007, 02:45 PM
Erik Mckenna's Avatar
Ah.. craig! come on man...... you need to sort that technical shee-it out brother hahaha!
" The reason the Irish are always fightin each other is that there are no other worthy opponents"
Old 05-31-2007, 02:46 PM
damnit, I got blue balls now.
Old 05-31-2007, 02:56 PM
Me like track days
Old 05-31-2007, 04:14 PM
Me like track days
Old 05-31-2007, 04:15 PM
Me like track days
Old 05-31-2007, 04:18 PM
Porsche Junky
mede8er's Avatar
Very nice...I need to pick up some of that Syl Glyde...as I'm sure my fittings are dry...
1986 930 RUF equipped
Old 05-31-2007, 04:42 PM
did you clear the IC after blasting it? I would suggest it as it won't stay clean for long.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-31-2007, 06:39 PM
Me like track days
Yeah, that was in my thoughts.
Which clear brand/type?
Old 05-31-2007, 07:34 PM
lite75's Avatar
what did you end up doing with the innercooler you bought?
Dan
75 930, 76 930, 83 SC EFI turbo
Old 05-31-2007, 07:45 PM
rsrfan's Avatar
Craig,
did you bail on the Blown Six?
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 05-31-2007, 07:46 PM
Me like track days
Looks like it - I bought EVERYTHING to install it - I mean every piece of OE Porsche parts required.......and due to the rearward placement of my particular engine it just flat out does not fit/clear the rear structure. Aaack...
Who wants a complete BlowSix 965 IC setup?
Old 05-31-2007, 07:55 PM
rsrfan's Avatar
Time to tube frame the rear ala a 935. Your teetering on the edge anyway, right?
JP
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 05-31-2007, 08:00 PM
Me like track days
I have the BlownSix right here.....it is a damn shame I can't install it.
On the edge is right ;-)
Old 05-31-2007, 08:26 PM
shaka's Avatar
Hey Craig,
Are you really going to get rid of your 965 IC? I might be interested.
Old 05-31-2007, 08:34 PM
Me like track days
I'm pretty certain.
What emission/cold start stuff do you still have?
Old 05-31-2007, 08:47 PM
lite75's Avatar
Craig,
Interested in your intercooler as well.
Is your G50 shortened?
Dan
Old 05-31-2007, 09:55 PM
7.0:1 > 11.3:1 > 7.0:1
Craig, too bad about the intercooler. I had been wondering when you were going to install it.
Roughly how far rearwards is your engine versus stock?
You said you waxed your intercooler. I did something similar to my intakes after bead blasting them and their appearance has stayed static since last fall and still no water stain marks. So far so good.
Edit: Is your breather hose to the oil reservoir kinked or is it OK. It looks like it may be kinked in the first picture.
Old 05-31-2007, 10:51 PM
I found that just krylon clear works pretty well. I have even done a light dusting of silver from 14-16 inches away then apply clear 5 minutes later and it look like a stock aluminum casting. works really well
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-01-2007, 05:11 AM
