Me like track days
RUF intercooler re-do, clean up and replumb project
1) Glass bead blasted the RUF intercooler - took 1.5 hrs - P21S wax on top
2) Cleaned up wiring for the RPM full boost enrichment delay switch 3) Adjusted the WUR to lower the warm control pressure for a bit more rich in the midrange 4) NAPA has a silicone paste which is ideal for sealing the IC rings 5) Rerouted/replumbed the 'IC in' temp sender from the air cleaner to the IC inlet
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno Last edited by Craig 930 RS; 05-31-2007 at 04:20 PM.. |
Me like track days
She-it.......hang on, pics aren't working........
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Ah.. craig! come on man...... you need to sort that technical shee-it out brother
hahaha!
" The reason the Irish are always fightin each other is that there are no other worthy opponents" |
damnit, I got blue balls now.
Me like track days
Me like track days
Me like track days
Porsche Junky
Very nice...I need to pick up some of that Syl Glyde...as I'm sure my fittings are dry...
1986 930 RUF equipped |
did you clear the IC after blasting it? I would suggest it as it won't stay clean for long.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Me like track days
Yeah, that was in my thoughts.
Which clear brand/type?
what did you end up doing with the innercooler you bought?
Dan
75 930, 76 930, 83 SC EFI turbo |
Craig,
did you bail on the Blown Six?
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Me like track days
Looks like it - I bought EVERYTHING to install it - I mean every piece of OE Porsche parts required.......and due to the rearward placement of my particular engine it just flat out does not fit/clear the rear structure. Aaack...
Who wants a complete BlowSix 965 IC setup?
Time to tube frame the rear ala a 935. Your teetering on the edge anyway, right?
Me like track days
I have the BlownSix right here.....it is a damn shame I can't install it.
On the edge is right ;-)
Hey Craig,
Are you really going to get rid of your 965 IC? I might be interested. David |
Me like track days
I'm pretty certain.
What emission/cold start stuff do you still have?
Craig,
Interested in your intercooler as well. Is your G50 shortened? Dan |
7.0:1 > 11.3:1 > 7.0:1
Craig, too bad about the intercooler. I had been wondering when you were going to install it.
Roughly how far rearwards is your engine versus stock? You said you waxed your intercooler. I did something similar to my intakes after bead blasting them and their appearance has stayed static since last fall and still no water stain marks. So far so good. Edit: Is your breather hose to the oil reservoir kinked or is it OK. It looks like it may be kinked in the first picture. Last edited by Jim2; 05-31-2007 at 11:07 PM.. |
I found that just krylon clear works pretty well. I have even done a light dusting of silver from 14-16 inches away then apply clear 5 minutes later and it look like a stock aluminum casting. works really well
