Boost Freak
Maxx1's Avatar
Angry I pulled my Perma-tune out and it failed the bench test...
Pins 1 to 4 should be 3,300 ohms, but mine shows open. The car does start and car run fine, but I've been having problems with it stalling when it warms up.
Pins 1 to 4 being open indicate the high voltage is out (according to Permatune). If that is true, I kind of wonder how the car ran at all?
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 07-11-2007, 10:15 AM
My mechanic has replaced 6 permatunes....
Old 07-12-2007, 08:52 AM
youngkang's Avatar
Go with Bosche unite if you want stock or if you don't mind doing little wiring go with MSD.
86' 930 red "Wild @ss Hotrod" Thanks John
Old 07-12-2007, 03:00 PM
I have a stock unit in perfect working order, I switched to M & W with my EFI conversion.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 07-12-2007, 06:23 PM
Wo ist die Rennstrecke?
DonE's Avatar
Why don't you talk to Permatune and give them a chance to comment/fix it? When installed correctly, they are great replacements for the $$$ stock unit. Mine worked flawlessly for years.
Old 07-12-2007, 06:57 PM
Boost Freak
Maxx1's Avatar
I did call and talk to a tech there. He said there is no repair available on the older units and suggested the new more robust black unit they sell.
I have a MSD 6A I think I will install this weekend .... I hear they will work ok. I just have to hope the tach signal is correct for my 82 VDO..... that and come up with a coil.
Old 07-12-2007, 08:02 PM
Use the MSD blaster ignition coil, Pelican should sell it. The exact match up component.
Old 07-15-2007, 03:21 PM
Boost Freak
Maxx1's Avatar
Yeah, maybe I should have. I hooked up an Accel high performance coil and my idle is all out of wack .... way too fast. At first I thought I had a vacuum leak but checked everything and all the hoses are connected. The throttle plate is not sticking. I don't know if it's the coil, but I will change it and find out.
The only bummer is, the tach terminal pushed into the MSD housing, so now I have to try and disassemble the unit to repair the connector.
Old 07-16-2007, 03:58 AM
