She's bad to the bone.Love that BMF look,if you ever get up to Taos,N.M. great roads up here.Stay safe.
Blackbird Pilot
RSR suspension with all new zinc plated hardware.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Tilton Clutch (adapter finally finished from the machine shop) ![]()
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
Wow - You must be itching to get behind the wheel of this thing! Now to date myself...."radical dude!"
Dan 88 930 blk/gry |
Blackbird Pilot
Engine is in
3.8 twin turbocharged liters of fury in the Blackbird...we're gettin' there.
![]() One of the mounts: ![]()
Looking good so far. I really dont feel like reading through all this but what throwout bearing are you using? Whoever owns that shop ought to clean it up, what a dump man.
74 911s neverending story. two feet and a jetta for now. |
Blackbird Pilot
Not sure on the throwout bearing - but as far as how the shop looks, not all shops look like hospitals. The last 917 I saw put together in Van Nuys, CA was in a shop in similar shape.....
Being an a$$ connoisseur myself, i can truly saw with authority that that rear is truly a work of art. Good job Gab and your shop is doing great job. Let me know about that t-shirt thing.
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
BTW, how far are you front spindles raised? Also, are u using a tranny cooler?
Blackbird Pilot
19mm and no tranny cooler for now. She won't see the track until next summer so I didn't figure i'd set that up until then. I'll hit you up on email for the Tshirt thing, i totally forgot to respond my bad!
And yeah, that is one heck of a rear isn't it ? ![]()
Looking very nice!
One Q, what's this spin on filter for? At least it looks like one. ![]()
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
Blackbird Pilot
I couldn't tell ya to be honest, I'll have to ask the shop. Its a 964 motor so....any guesses?
Forced Induction Junkie
964 factory engines had a secondary oil filter console where there used to be a oil cooler.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
A fellow Pelacanite
I think that filter will filter oil on the way into the engine.
Our 930's only filter oil on the way out of the engine, the filter is screwed in the top of the tank. I don't see why the 964 would be the other way round, but I guess it's possible.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
964's do it both ways. Sorry couldn't resist!
From what i recall, this secondary oil filter the byproduct of the race department's evolution of the flat-six. It is merely a bolt-on replacement to where the engine oil cooler goes. I think Partric Motorsports or someone carries it. If ur running a good front cooler, finned lines, etc , the engine cooler is superfluous.
Item #44/58 shows the oil filter console for the C2 964's.
Blackbird Pilot
Bravo guys...cool stuff! Makes sense as it was originally a C2 case.
Gab,
dude.. you are such a tease!!! ![]() Looking way good!
RGruppe #180 So many cars.. so little time!! |
964 Normally aspirated cars used a smilar oil filter system as the early cars, the biggest difference being that the filter was first in line out of the engine on the oil's path through the front cooler and back to the engine. Still after the engine though
965 cars used the engine mounted oil filter, filtering the oil on it's way to the bearings, etc, versus on the way back to the tank. I assume to make way for the heater fans/hoses mounted in the rear fender wells. The 965 had no oil filter for the scavenged oil ![]() It wasn't until the 993 that Porsche installed both an engine mounted filter for pressure feed side as well as a larger filter for the scavenged oil, mounted near the oil tank. - probably the best oiling system yet for their drysump system. OK, enough oiling system trivia, my real concern is: Reaper, what are they doing for a front oil cooler setup? I hope it's adequate! W/ all that power and no engine mounted cooler, you're going to need ALOT of front cooler. ![]() You can fit 2 964/965/993 front coolers stacked end to end behind the opening in your 935 bumper w/ fittings facing outwards, plug the temp sensor holes, run some -16 lines w/ metric fittings ,(or use 30mm mertic adapters w/ AN fittings) and plumb them in series(allowing the oil to go through both coolers)
Professional Overcomplicator |
Blackbird Pilot
Oil cooling setup is a custom made front cooler that takes up the entire front opening with 2 additional coolers behind the headlights with fans. All lines are stainless steel braided with -16 AN fittings
![]() Onboost: a tease huh? Hahaha I just can't wait to finally see her.
