Macht Schnell
les_garten's Avatar
Originally Posted by RarlyL8 View Post
Have you noticed the number of Rennlisters now on this forum?
Rennlist absolutely sux. Too many egos for my blood.
Les, I probably could fab one up but I'm way too busy to take on anything else. I do have a stock up-pipe that has had the bottom cut off and a silicone hose added (for use with a K27) if anybody needs/wants something like that.
Hi Brian,
I thought about cutting the bottom off mine but really want a pipe with silicone Transitions on both ends. If ya think you might have some time in the future, let me know.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 12-23-2007, 06:30 PM
A fellow Pelacanite
NathanUK's Avatar
Glad you all enjoyed that
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-23-2007, 11:36 PM
I can offer to fab a few tubes on selfcost.
We bend and weld aluminium tubes often
in my company.
I already have idea how the tube can be made.
Only I like to develop design and compare
measurments with you.
happy holidays
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 12-24-2007, 12:28 AM
the cone looks familar. It is an off the shelf stainless piece
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-24-2007, 04:16 AM
Macht Schnell
les_garten's Avatar
in my company.
happy holidays
Falk
Hi Falk,
I'm game for sure. Just let me know what you need from me.
Thanx!
Les
Old 12-24-2007, 05:34 AM
Crotchety Old Bastard
RarlyL8's Avatar
The cone is similar Ben but you need to add the attachment points and angles on both ends.
If you have the time go for it!
Old 12-24-2007, 05:47 AM
I would need a sample
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-25-2007, 10:14 AM
does anyone know whose car the green one on the first page is? it is the one with the grey colored ic and newer a/c..
Old 01-19-2008, 12:09 PM
resident samsquamch
sand_man's Avatar
Reviving from the dead
Thought I'd provide yet another update:
In a funny twist, I am now rocking the factory OEM 965 boost pipe that I acquired - the blue whale fleshy, Dirk Digler Kong, from post number 33 in this thread!
I had to trim about 1.5" off the bottom (end that connects to the turbo) in order for my 965 intercooler to sit where I wanted it.
Here's what I've noticed using the factory tapered pipe: the boost really comes on with even greater linearity than before. I mean the delivery, especially with the efficient K27HFS, is oh so smooth. I think my home made pipe was still allowing for some of that explosive "light switch" effect...which is really what I was used to feeling...perhaps that's why I thought I liked the home made straight pipe better??
At any rate, the kong stays on for now...
-jeff
Old 03-14-2008, 10:37 AM
Macht Schnell
les_garten's Avatar
Hmmm, you would think with that showing up on your "seat of the pants dyno" that you wold see the boost building at a different RPM for one pipe or the other.
Old 03-14-2008, 10:56 AM
resident samsquamch
sand_man's Avatar
Yes, I catch your drift. Full boost still seems to come on about the same time. Perhaps it's the cone's ability to hold and transition more air that is causing me to feel this subtle change in drivability? Whatever the case, I'm liking more and more how smoothly it's all happening.
-jeff
Old 03-14-2008, 11:41 AM
Macht Schnell
les_garten's Avatar
I was thinking more on the lines of threshold boost. Any difference there?
Old 03-14-2008, 12:01 PM
resident samsquamch
sand_man's Avatar
Ah. This is something I did not pay much attention to...as far as when the boost actually started to come on.
-jeff
Old 03-14-2008, 12:11 PM
rufrob's Avatar
Thanks for this greatly informative thread. I just managed to install a 965 intercooler on my car. It wasn`t as difficult as I imaged. The hardest part was getting the pipes into the silicone. They were very tight. Also there is very little room to secure the clamp at the turbo. Lots of scraped knuckles. But wow!!! What a difference in performance!! I can hear the turbo whistling away all the time now. and the exhaust also seams deeper. But now I am getting occasional puff of smoke when decelerating with the engine. I wonder, has anyone tried hard plastic tubes instead of aluminium?
Never give up
Old 09-15-2013, 06:22 PM
