-   -   How much power do you have? How did you get there? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/367717-how-much-power-do-you-have-how-did-you-get-there.html)
Craig 930 RS 09-20-2007 07:53 PM
They sure are. With Hoosiers, they are quicker per lap than my 930 -
RarlyL8 09-20-2007 08:29 PM
A/F ratios are A/F ratios.
If you can achieve 12.2:1 without a fuel head mod then all you are doing with the fuel head mod is wasting gas. There is no sustained boost on the street so the engine does not need to be fuel cooled.
Race cars and high HP engines are a different animal.
Optimally you should tune all 3 points of the WUR so an RPM switch is not needed. I would never presume that boost hits at the same RPM in every gear in every situation.
I think I've mentioned in the past that a friend - with absolutely stock internals; ie everything from stock P&Cs, 7.0 CR, stock 930 heads and manifold - but with cams, B&B headers, muffler, & stock K27 - achieved 360+ RWHP.
What boost level was that at? My engine, when dynoed in that same configuration, put out ~320RWHP @0.7bar boost.
Lots of apples and oranges here. The original post asked for formulas to achieve HP. There are many different ways to achieve the same HP levels, let alone varying degrees of power. Pat's SC engine lays down the same power as an early stock US 930 while Craig's monster CIS engine puts down more power than some of the EFI motors. Hell you could run a stock engine on toluene at 1.5bar and hit 400+HP (for a little while - ha!).
Jim2 09-20-2007 08:51 PM
Ramblings... (Craig's post with the Holcomb dyno chart)
I'm sick and tired of..................
930 cylinder heads! These engines are crying for some 993 heads, BIG intake manifolds, and BIG headers. At 550cc per cylinder my ports and scrap headers are about the same size as a stock Austin mini (the early one!). HP requires breathing regardless of turbo or NA and I feel my motor is simply being choked off. I feel this is the biggest difference between the majority of us, and the "Holcomb" motor dyno chart.
Years ago I got my hands dirty building four cylinder turbo motors. Some of my friends were running in the territory of 190 HP/Ltr at very modest boost levels (Under one bar). This was a good display of well tuned engines with a solid foundation of the fundamental components required to make HP.
My car is making 130 HP/Ltr nearing one bar. The Holcomb motor makes somewhere in the range of 180-190HP/Ltr at one bar.
Anyone have some "good" heads laying around?
End rant!
wcarson 09-20-2007 08:54 PM
For whatever its worth:
351 rwhp/ 348 ft-lbs on a dynojet dyno (approx 400HP crank)
KKK K27-7200
CIS with IA fuel head mod
0.8 bar
Elgin SC 330 cams
Kokeln IC
Ported heads
Euro heat exchangers with borla muffler, no cats
EBS valve springs
ARP fasteners
The car is an 82 non sunroof 930. It's fast, although I am sure nothing like the EFI set ups. My biggest street victory was a C-5 Z06 on the freeway from 65-140mph before we had to brake. I was maybe 3 car lengths ahead. I am sure that a new ZO6 would hand my butt to me. I guess that's was EFI is for though......
WKC
San Diego, CA
Jim2 09-20-2007 08:55 PM
I need to "un-subscribe" before this starts costing me more money!
Craig 930 RS 09-20-2007 09:00 PM
Very true. There are engines which never need an IA fuel head.
#1 manage the fuel you have via adj. WUR, and check AFRs.
"Optimally you should tune all 3 points of the WUR so an RPM switch is not needed. I would never presume that boost hits at the same RPM in every gear in every situation."
Without the fuel head it may be theoretically possible.....but w/o the head you normally run out of fuel up high when the WUR is tuned for low to mids. RPM switch is required for a proper job - at that point, after everything el$e, scrimping on leaving out the low cost RPM switch is just foolish.
Adj WUR & RPM are a must, with the fuel head optional dependent upon the resultant AFRs.
Sounds trite, but a hi-po 930 for the everyman just does not cost all that much.
RarlyL8 09-21-2007 05:52 AM
The RPM switch is a device that allows you to move an entire range of function. It has no provision for fine tuning.
You are talking about high HP applications, those above 375RWHP. Those issues simply do not apply below that power level. This is not a theory. The RPM switch does nothing to add fuel, it simply delays the onset of boost enrichment. I don't have one on my engine and the ratios are perfect.
Back to our regularly scheduled program....
Are there any patterns forming? How about a simplistic build guide:
255 RWHP - stock Euro
300RWHP - turbo, cams, 0.7bar
350RWHP - turbo, cams, intercooler, headers, 1.0bar
375RWHP - turbo, cams, intercooler, headers, 1.0bar, head work
400RWHP - turbo, cams, intercooler, headers, 1.0bar, head work, fuel system mods
450+RWHP - all of the above plus EFI
Craig 930 RS 09-21-2007 06:18 AM
I like the idea of the guide Brian has, but you will not need 1.0 bar to get 350 hp - and I personally would not do 1.0 bar without fuel modifications.
The Brian Leask adjustable WUR allows 3 adjustments:
Cold start
Warm run
Full boost enrichment
The RPM switch is an excellent idea because you do not need the FULL, and I mean all hell breaks loose full gush fuel dump at 3,000 rpm, the point at which modern turbochargers produce FULL BOOST. It is 'tunable' by inserting an rpm plug of varying RPM full boost threshold. Mine happens to be 5,200 rpm - up from 3k stock.
Again, there are variables which need to be taken into account here.
If you require the fuel head THEN wish to take that extra step in order have a higher HP 930 engine (yep, easy to do and not a stretch from a mid-300s hp engine), then an RPM switch is also required.
So, to "get there" HP-wise, I'd suggest the WUR 1st in conjunction with the K27 HFS, headers, 8 bar and probably $$$ cams.
For a street beast, the leap to safe, high HP is a tiny step dollar wise from a 320-hp car.
And don't forget that full CIS checkup prior to that HP bump - including injectors!!!
patkeefe 09-21-2007 08:09 AM
Regarding Craig's point on the IA head:
I realize that my SC and the 930 are a bit different, but principally the same. I was unable to get AFR's below 13:1, even with the old homemade adjustable SC WUR. The IA mod allows a lower AFR (they told me they could get a point of AFR with the mod on my SC fuel head, and they did). The Brian Leask WUR seems to make the system way more compliant and tunable. I tend to agree with Craig on WUR first, then fuel head mod. I have no experience with Brian's RPM switch. I would like to know what the difference is between the RPM switch, and the boost threshold adjustment on the WUR.
I can say that my street AFR's are just right, but I was 10:1 AFR on the track for the past two days. My little engine was on boost basically all the time, except for the corners. I may be able to tune that with the WUR. I'd like to know what you guys are seeing on the track.
RarlyL8 09-21-2007 08:15 AM
That is precisely the area I am typing about. That 3000rpm dump point is not an absolute and can be tuned out. An rpm switch does not reduce the dump, it just moves it so that the extra fuel dump is in an area where it can be used so it does not show up on the graph as excessive. It does work as it was designed, just not the way I would go about getting there due to the variables seen in boost threshold. I prefer to control boost enrichment by boost signal, not by rpm.
The above "guide" is very simplistic. There are many ways to achieve the same HP levels.
Craig 930 RS 09-21-2007 08:29 AM
The fuel head will cost $500-ish, you may not need it, and you must install (not a simple job, drop the engine)
The fuel head allows a known and absolute margin of safety that can be 'dialed back' using the RPM switch and 3 way adjustable WUR.
$500 (?) for the head, $300-ish for the WUR, and not much at all for the RPM switch setup gets you all the way there for virtually guaranteed safe AFRs. Just judge if you want to jump all the way in dollar wise all at once when you *may* not need to.
High HP 930 engines almost always need the fuel head anyways, so that is the route I took towards the:
"How much power do you have? How did you get there?"
If high HP is your goal, I'd do all three. The fuel head may not be required, but for me it was.
As another aside - 'getting there' is fairly easy due to Brain Leask's WUR/RPM instructions.
Brain has written some of the very best manuals I have ever seen.
DSPTurtle 09-21-2007 10:19 AM
How can we get a copy of Brian's "manuals"?
look 171 09-21-2007 10:37 AM
Originally Posted by RarlyL8 (Post 3490063)
It would be difficult to gets past 350HP without head work. That is where I think Sandman's will dyno unless porting was done during the twin plug process.
The modified fuel head is not needed until your current fuel head runs out of adjustment and fails to maintain 12.2:1 A/F on boost. That happens somewhere around 375RWHP.
Head work was done by the PO. Maybe I need to take a look..I am in So Cal, so I didn't it was necessary to adj the wur all the time.
WERK I 09-22-2007 04:56 AM
Warm-Up Regulator is somewhat of a Bosch/Porsche Factory misnomer. It has absolutely nothing to do with the type of climes you may live in. The accurate term would be Fuel Pressure to Fuel Distributor Regulator. The Auxiliary Air Regulator is more like a Warm Up Regulator. It's only necessary during the cold start or near cold start engine startup.
911nut 09-22-2007 06:01 AM
This is Don Hollinigs' car. He's getting 12/1 AFR's with a .9 bar spring and no fuel head mods:
http://www.youtube.com/watch?v=0yN21pTCAwA&mode=related&search=
RarlyL8 09-22-2007 06:02 AM
We talk a lot about adjusting the WUR because most of them are very old and out of spec or used on modified engines. Adjusting them is usually a one-time deal. You check your A/F ratios, adjust if needed, and lock it down.
Could be that the WUR name stuck (pre-911) because the cold pressure function is most noted when it falls out of spec and your car becomes difficult to start. The dealerships and shops simply tossed it out and installed a new one. I guess we should be thankful that Bosch did not incorporate the WUR into the fuel head.
c2turbo 02-20-2008 04:41 PM
590 RWHP (680 crank hp) 1.1 bar pump gas with plenty of room left just ran out of turbo on the top end about 6400rpm's
91 C2turbo
3.8l 964 based block ( started life as a RUF RCT )
JB cast iron CYL
GT2 cams
JE pistons
Carrillos rods
JGS wastgates and blowoff valves
GT28rs twins
DTA EFI (tuned by wayne ) TPG
BLA BLA BLA
oh yea the car weight = 2873 with 1/4 tank
Car does not even breath heavy and want more boost
http://www.youtube.com/watch?v=PbtvC39I9Qs
Craig 930 RS 02-20-2008 04:53 PM
Sweet Mother of God.
patkeefe 02-20-2008 05:06 PM
That gauge is really slick. I could replace my six gauges under the dash with that!
c2turbo 02-20-2008 05:09 PM
Thank you
www.inyourfacegauges.com
patkeefe 02-20-2008 05:16 PM
Is that a one time deal; maybe the prototype?
These being offered to the sporting public?
And, you're welcome! That is really clever.
Pat
c2turbo 02-20-2008 05:33 PM
We have been offering these to the public for about the last 3 weeks the company name is IN-YOUR-FACE-Gauges the website should be completed by tomorrow ( I hope ) we are releasing a second gauge that fits in the clock
here is a sneak peak at the prototype
http://forums.pelicanparts.com/uploa...1203561124.jpg
http://forums.pelicanparts.com/uploa...1203561141.jpg
David 02-20-2008 11:57 PM
c2turbo, very nice build!!!
Can the gage interface with a Motec M600 through CAN?
YermanCars 02-21-2008 06:37 AM
489rwhp @ 16psi, this was w/ the stage 3 protomotive chip.
http://media.ams-evo8.com/videos/amsmisc/PorscheDynoRun.wmv
Comming soon, dta fast pro8 twin plug w/ sequential injection looking for 600rwhp track monster
http://forums.pelicanparts.com/uploa...1203608159.jpg
Waiting, waiting waiting,
http://forums.pelicanparts.com/uploa...1203608232.jpg
Gino 02-21-2008 08:28 AM
Since page 1, there's been some significant money spent on mods to gain POWER, but I didn't notice anyone else suggesting gearing. Its not all about HP & TQ. There is the 'drivability issue' and without question I found the gear set changes to a shorter 2, 3 and 4th to be the biggest factor to the leveraging of these mods. Without question the car feels three times as fast (quicker) with the COMBINATION of more power and short gears.
Not being a racer, 145 mph top speed is fine with me. The best part is the fact that traveling on regualr side roads at 45-60 my 3rd gear allows for instant boost as I'm 'in the proper rpm zone'. before I had to wind out driving in 2nd, or practcally idle if in 3rd. And similarly when on the hwy at 65-75 again I'm in the zone for instant boost already at 3000 rpm.
Just another observation... does anyone have the similar mods spoken, but did an R&P change? not quite the same result as gear sets, but anything to and along the lines of Drivability and Fun Factor?
Craig 930 RS 02-21-2008 08:43 AM
True enough. My 930 has the G50/50 5 speed, and while on track I find myself shifting, uh, quite often as it rockets through the gears.
On the street/highway 3rd and 4th gears respectively are the absolute sweet spots for fun!
Gino 02-21-2008 09:04 AM
Craig-
what is the R&P ratio and the 1-5 for the G-50/50? I wonder if they are the same resultant ratios of my stock R&P with the shorter 2, 3 and 4th.
WERK I 02-21-2008 10:30 AM
Yes, I have a short R&P like yours with the factory gears 1 thru 4. First gear is awful. Just wa-a-a-ay too short to be practical. When I rebuild the box, first gear will be taller, closer spacing to 2nd. You're right about 4th gear cruising 3000RPM....it's a rocket ship to over 130MPH. :eek:
Craig 930 RS 02-21-2008 12:15 PM
2nd gear set - 2.05
4th - 1.212
5th + final drive of ? gives 3,200 rpm at 80 mph
A bit busy now to really dig for more info
930gt-40r 02-21-2008 12:36 PM
Yerman, your motor looks like you did your motor much the way mines was.
By the way, your brother gave me the hook-up with that hot housing- Thank you for helping me with that.
930gt-40r 02-21-2008 12:43 PM
By the way, did you hear about Eddie's car last weekend?
rudy 05-18-2008 08:20 AM
294rwhp and 344rwtq
78 Euro 3.3
Flowmaster muffler
Stock from top to bottom
Its in a 1969 911T weighing 2300lbs
ZLP 05-18-2008 09:00 AM
ZLP 05-18-2008 09:01 AM
Hey Jim, are you still liking the SDS system? I am about to pull the trigger on an EMS soon and that one is still high on the list.
jbailey930 05-18-2008 02:26 PM
Went throught the first three stages described by Brian until head stud on #3 cylinder broke.
Lots of help from Stephen. Charlie at Intersport in NVa completed the build:
5 angle valve grind
Vmax racing valve springs
Titanium retainers
ARP rod bolts
.5 bump compression stock 930 heads
dry lube skirts
Webcam SC cam grind
Steel studs 993
Modified Kokeln I/C to fit intake
Carrera intake
ported heads to intake
Motec M48
High pressure fuel pumps and regulator
951 injectors
GHL heads
K27 special
.8 bar
404 RWP on 98*F dyno jet at TPC Mike Levitas shop
389 Tq called it a day
PS, dont forget to powder coat the bits to make it look purdy :)\
oh, yeah here is short video of 95% run with some ice on the I/C
http://video.google.com/videoplay?docid=-3749305718939234138&pr=goog-sl
930gt-40r 05-18-2008 05:18 PM
Eddie put down over 1200 to the rear wheels on an aircooled motor.
I USED to make 496 to the rears untill my cam chain tensioner said otherwise...
empire0007 11-18-2012 10:01 AM
I love the guage work. How much did that cost you?
91 C2turbo
JB cast iron CYL
GT2 cams
JE pistons
Carrillos rods
GT28rs twins
BLA BLA BLA
Custom Porsche C2turbo PLX gauge - YouTube
empire0007 11-18-2012 10:03 AM
Very nice, i'm interested.
gsmith660 11-18-2012 02:23 PM
The thread is 4 years old and I think he is out of business as someone inquired about in your face gauges a while ago and the website was down.
SCHNELE 11-18-2012 03:12 PM
No he is still in business he just did a gauge for me.
