I will get his contact number in my office and post it up.
Did one for me. He does quality work!
Sent from my MB855 using Tapatalk 2 |
I know it's an old post but..
Stock 3.3 motor Carrera intake (with custom adapters to 3.3 heads) S262 bullseye turbo B&B headers Full bay intercooler MS2 EFI E85 fuel KEP PP & kevlar disc 450rwhp @ 17psi @ 5900 435rwtq |
Drmatera, those are fantastic numbers. I hope I'll be able to copy that setup some day.
Lincoln. I want one of his gauges as well. Which one did you get? Can you forward his contact info to me. Thanks. Tate
oh well
3.3 motor pancake manifold opened to 38mm extreme cylinder heads garrett gt 35 turbo bell full bay i/c mode headers ms2 efi e-85 fuel kep pp and disk 490 rwhp @6300 @14.5 lbs 486 rwtq carrera manifold next week!!!! |
no dyno, but its a torque monster!
3.4, 8:1, Carrera heads by Xtreme, large valves, P&P. Carrera manifold, SDS EFI, Meth Injection, twin plug, GT35R, 1.75 GHL headers, B&B muffler dual out, Carrillo Rods, ARP studs/bolts, Kep stage 1, SC cams. any guesses? Philip
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/580883-another-efi-conversion.html |
Comparing Granny Smith to Red apples but:
- Carrera 3.2 with 3.4L, 7.5:1 CR P&C's - 1-bar 60-1 with 0.81 A/R turbine using 1 5/8" headers - All stock low-end (minus pistons), cams, intake, TB - Full bay IC - 55 lb injectors w/twin -044 pumps - 431-447whp on Motronic/Protomotive chip - MegaSquirt whp TBD |
Hmmm that's good to know! I didn't think you could touch 400rwhp using the CIS. I think my next upgrade is a better and bigger intercooler. What is the best bang for the buck there? My car has a guesstimated 340-350 rwhp. I am nervous about running that 1 bar spring.... I usually don't push my luck with the throttle pinned too long http://forums.pelicanparts.com/suppo...s/visslaan.gif |
There was a nice 930 on the dyno next door with plenty of upgrades and a GT35 turbo. They managed 425rwhp but the a/f was climbing towards the 13's so he stopped there. Actually locked it down in the 400rwhp range to be safe
Had to drop boost back to 0.8bar and limit him to 5,200rpm until he could fix the lack of fuel up to. Still did just shy of 400whp with typical bolt-ons + SC cams. |
Interesting thread!
I have half of my mods completed: 1986 930 with a Stock 3.3 Motor/stock IC/Stock CIS/RUF VB .9 BAR Boost My Mods: K-27 HFS Turbo B&B Headers B&B Exhaust Total Parts and Labor for that upgrade = $4927.92 Future Mods: RUF IC Adj WUR/ RPM Solenoid I have not been able to get it dyno'd yet. What would I expect to have for HP & Torque? |
You should have ~350WHP with that combo.
Open up the internals of the B&B muffler from 2.5" to 3" and remove all the baffles and everything but the 1" of stainless steel packing from the inside and you'll get around another 10-15 horsepower.. and it'll sound better with some nice turbo whistle added in without getting much louder.
SC or 964 cams would help too. |
Fabspeed IC, headers, single outlet muffler, Tial 46mm .8 spring, K27/29, Patrick MS LWFW and clutch. Leask WUR, MSD 6al programmable, 350 rwhp, 360 rwtq. Lambda is .90 at 6400 rpm 12.7 AFR. Thinking about the fuel head mod.
http://forums.pelicanparts.com/uploa...1385331846.jpg |
I have no idea...they don't have any dynos anywhere near here out in the sticks. I'm guessing 370 tops at 1.0 bar. But this morning, I think it was closer to 450 with the 28 degree air!
I was told that the dyno at the speed shop which is a Dynapack was nicknamed "the hearbreaker" because it reads low. It read 393 rwhp on a Mustang dyno several weeks before with a 1 bar spring. It actually was boosting 1.1 because of the unrestricted exhaust. Too much boost and advance (look at the torque!) for the fuel flow.
http://forums.pelicanparts.com/uploa...1385334853.jpg The dynapack connects directly to your wheel hub with a load, so the numbers are pretty spot on or somewhat conservative; at least that's what I'm told. I think the biggest concern is how fast the boost comes on (psi), the fuel has trouble catching up when it hits that hard and fast. The MSD programmable made a world of difference, we couldn't retard the advance enough until we installed that. The acceleration is very smooth, almost linear and most importantly safe. |
i took a little different route to get more power. i replaced the 3.4 liter modified turbo motor in my '78 930 with a mast motorsports drive by wire ls7 motor. the car has no frills and weighs in at a bit less than 2300 pounds. http://forums.pelicanparts.com/uploa...1385343279.jpg
Any time, we'd be happy to work with you on it, get you the next 60hp/100ft.lb. or more. :-)
Currently going together:
3.3 litre
Flowed case 7.5-1 Cr 2.5 race cams High butterfly ITB's Well massaged heads 96 lb injectors TEC3-R engine management 935 headers Twin 54mm custom built turbos 23 lbs boost water-methanol injection Aluminum rods Horsepower- you get the idea! |
[QUOTE=kenikh;8232427]
8.5:1 CR on CIS seems pretty aggressive. Normally the territory of EFI builds IME. What boost level are you planning to run? |
[QUOTE=jwasbury;8232999]
From your post, it sounds like you are recommending that I should. |
I would if it was my car.
I know there is the rationale that small ports = higher port velocities, and thus better low speed drivability, and if you choose follow this, no problem. You're entitled to your opinion. My $0.02: I used to adhere to this as well. If Ruf and Andial did 36mm ports, then that has to be best, right? But the more we ported heads, the better and better the cars got. More punch. More torque. More HP. More drivable. Now 36mm is our minimum size (most you can bore stock plastic injector blocks) and most of our CIS engines are 38-40mm (40mm is ID of stock CIS gasket). Heck, when SC and Carrera heads were plentiful, a lot of builders used to slap them on 3.3L Turbo engines. A 3.3L with 41.5mm 3.2L heads is by no means a lazy engine off the line. |
I defer to your expertise. I'll call Ollies and tell them to add porting to the bill. Question then becomes: What's a set of aluminum injector blocks from TurboKraft run if I go with >36mm ports? Do you port the exhausts to the same spec?
I opened up my intake ports to 40mm to match them to the 40mm aluminum CIS injector blocks I have. Also opened up the holes in the flat manifold to 40mm and smoothed out the internal edges around them leading into the inside of the manifold best I could.
There's no flat spots or shortage of off the line and around town torque below 3000 rpm, none at all! Try it you'll like it:) |
If you have a gasket set, you'll only need the blocks & insulators, $470. Exhaust ports -- I'd open them, too. At some point you're limited to the ID of your exhaust manifolds. What is the OD of your manifolds' primary pipes? |
I would!
Exhaust port specs given euro HEs? 38mm or ?
I know no one wants to be on the hook for me making a decision, but unless someone has a reason to go another direction, I am leaning to 38I/38E, given I am currently running Euro HEs. Again - input appreciated and I promise I'll post a dyno pull once all is said and done to repent for diverting this thread. :) |
My car is a Carrera and has far more low end torque than a friends 965 with CIS.
I can even chirp the tires now (new 285's) by popping the throttle in first at idle speeds with my G50. I made a recent change to my EFI and discovered this. It's really torquey, and I think Carrera are 41mm ports?? Another words, do it!! :) |
https://www.youtube.com/watch?v=3W9nPlRqNo8
I have heard that anything over 550WHP for aircooler engine will damage the motor, unless you have the flat fan, like the 935 engine? Do any of you guys run that kind of power on track? If so how much power and how long has the engine lasted? The head is the issue from my understanding?
| All times are GMT -8. The time now is 03:35 AM. |
