Any time, we'd be happy to work with you on it, get you the next 60hp/100ft.lb. or more. :-)
Currently going together:
3.3 litre
Flowed case 7.5-1 Cr 2.5 race cams High butterfly ITB's Well massaged heads 96 lb injectors TEC3-R engine management 935 headers Twin 54mm custom built turbos 23 lbs boost water-methanol injection Aluminum rods Horsepower- you get the idea! |
[QUOTE=kenikh;8232427]
8.5:1 CR on CIS seems pretty aggressive. Normally the territory of EFI builds IME. What boost level are you planning to run? |
[QUOTE=jwasbury;8232999]
From your post, it sounds like you are recommending that I should. |
I would if it was my car.
I know there is the rationale that small ports = higher port velocities, and thus better low speed drivability, and if you choose follow this, no problem. You're entitled to your opinion. My $0.02: I used to adhere to this as well. If Ruf and Andial did 36mm ports, then that has to be best, right? But the more we ported heads, the better and better the cars got. More punch. More torque. More HP. More drivable. Now 36mm is our minimum size (most you can bore stock plastic injector blocks) and most of our CIS engines are 38-40mm (40mm is ID of stock CIS gasket). Heck, when SC and Carrera heads were plentiful, a lot of builders used to slap them on 3.3L Turbo engines. A 3.3L with 41.5mm 3.2L heads is by no means a lazy engine off the line. |
I defer to your expertise. I'll call Ollies and tell them to add porting to the bill. Question then becomes: What's a set of aluminum injector blocks from TurboKraft run if I go with >36mm ports? Do you port the exhausts to the same spec?
I opened up my intake ports to 40mm to match them to the 40mm aluminum CIS injector blocks I have. Also opened up the holes in the flat manifold to 40mm and smoothed out the internal edges around them leading into the inside of the manifold best I could.
There's no flat spots or shortage of off the line and around town torque below 3000 rpm, none at all! Try it you'll like it:) |
If you have a gasket set, you'll only need the blocks & insulators, $470. Exhaust ports -- I'd open them, too. At some point you're limited to the ID of your exhaust manifolds. What is the OD of your manifolds' primary pipes? |
I would!
Exhaust port specs given euro HEs? 38mm or ?
I know no one wants to be on the hook for me making a decision, but unless someone has a reason to go another direction, I am leaning to 38I/38E, given I am currently running Euro HEs. Again - input appreciated and I promise I'll post a dyno pull once all is said and done to repent for diverting this thread. :) |
My car is a Carrera and has far more low end torque than a friends 965 with CIS.
I can even chirp the tires now (new 285's) by popping the throttle in first at idle speeds with my G50. I made a recent change to my EFI and discovered this. It's really torquey, and I think Carrera are 41mm ports?? Another words, do it!! :) |
https://www.youtube.com/watch?v=3W9nPlRqNo8
I have heard that anything over 550WHP for aircooler engine will damage the motor, unless you have the flat fan, like the 935 engine? Do any of you guys run that kind of power on track? If so how much power and how long has the engine lasted? The head is the issue from my understanding?
| All times are GMT -8. The time now is 08:09 PM. |
