e170drvr's Avatar
afr guage placement
Where are you guys with afr guages, installing them in the cockpit I would like to put mine in the center console somehow, but there is too much junk in there already. central locking and ac controls.
Old 02-11-2007, 05:57 PM
I have mine with a shift light and boost gauge on the left pillar
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 02-12-2007, 04:02 AM
wcc wcc is offline
wcc's Avatar
Do you have pics of this? I'd like to see this setup...
Bill
997.2
Old 02-12-2007, 06:55 AM
I also am installing a fuel pressure gauge for added safety since I have aftermarket fuel pumps
1986 blk 930
2000 expedition
Old 02-12-2007, 01:55 PM
89turbocabmike's Avatar
I have an innovate WB system and gauge. I made a small aluminum bracket that is double stick taped(auto trim stuff) to the steering column so that I can see it while on boost.
Old 02-12-2007, 08:50 PM
wcc wcc is offline
wcc's Avatar
Those are some sweet setups! Thanks for the pics.
Bill
997.2
Old 02-13-2007, 06:48 AM
I tried it on my steering wheel colum but it was to low and to close to me . I can hardly read the gauges so it easier to see the gauges higher and to the side. I am also 6'4" .
1986 blk 930
2000 expedition
Old 02-13-2007, 05:04 PM
kas930's Avatar
It took a little work, but I was able to mount mine in the ashtray...
Old 02-13-2007, 05:17 PM
Mine is a fairly inexpensive (~$400) WMS. I am currently doing a CIS to M48 conversion and don't know if this will work with the new setup, so I may have to get rid of it.
But regardless, it is small enough to fit into the slot at the bottom of the center console.
Olli Selander
1989 930 - 3.5l - M48 - G64/51
Old 02-13-2007, 05:32 PM
KCPSG's Avatar
Re: afr guage placement
I cut a new panel out of aluminum and removed the central locking button ( I found that I never used it...so I wouldn't miss it) I put the AFR gauge where my clock used to be.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 02-16-2007, 08:10 AM
Send a message via AIM to FlashGordon
Steven P., where did you get those A-Pillar gauges and mounts?
Old 02-16-2007, 06:50 PM
dewolf's Avatar
kas930, job well done mate, that looks factory.
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss.
In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians.
Old 02-16-2007, 07:12 PM
Send a message via AIM to Ag02M5
Inquiring minds want to know!!!
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 11-07-2007, 10:55 PM
Jeff Alton's Avatar
I have a small digital guage mounted on a bracket just below the speedo. Easy to see. I also have toggle switch mounted to switch the display between the left bank and right bank of cylinders (on a NA motor mind you)
cheers
www.turn3autosport.com
Old 11-08-2007, 12:13 PM
onboost's Avatar
[QUOTE=kas930;3101449]It took a little work, but I was able to mount mine in the ashtray...QUOTE]
Nice job kas... I really like that! Right color for my car too!
P-
RGruppe #180
Old 11-08-2007, 12:31 PM
iamchappy's Avatar
Mine on the pillar..
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-08-2007, 07:15 PM
Originally Posted by iamchappy View Post
Mine on the pillar...
I take it you just screwed the bracket into the pillar?
Definitely funtional but I want a more factory look like the molded pods offer...possibly covered in leather.
RT
Old 11-08-2007, 09:22 PM
