Stronger Rear Axles for 930
I am looking for stronger rear axles for 930 with G50 gearbox.
Is someone out there that can recommend a good manufacturer. I am using 621hp / 705Nm engine Thanks ![]() |
OMG what a sick cockpit!! love the wheel the F1 display, sequintial box, man thats fantastic , KEEP us update on the progress of this car! and MORE PICS!!!!!!!!!!!!!!!1
Forced Induction Junkie
You might try FabCar Engineering. I know of one racer here in Wisconsin that had half shaft and axle stub(the next weak link) issues. They were able to provide solutions to the problem.
fabcar-usa.com
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I've heard that stock 930 axles are used as the "strongest" on most off-road applications, dune buggies and such. Something to think about, nonetheless.
Wer bremst verliert
Patrick Motorsports stated the carrera items they sold me with a G50 were fine for at least my 500hp but not sure how high.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Where did the CF dash come from ???
1958 Karmann Ghia |
On some of my customers big power Ultima GTR builds and RCR GT40 kit cars I've been using these CV's:
http://www.vwparts.net/MB98-5096-B.html Lightened chromoly 934 variants. Coupled those with GKN gun drilled chromoly tubular axle shafts. Those cars are in the 6-800hp range on a regular basis running chevy/ford v8's through G50's or G96's and running big 300+ series tire width in back too. No issues there, we're breaking gearboxes before breaking halfshafts or CV's ![]()
Adam Hennessy |
Try The Driveshaft Shop- I have heard they made a porsche axle.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Blackbird Pilot
Looks like the Getty Design dash
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
one more picture
934 has different bolt circle – someone told me we could get 31 splines axles and use 930 CVīs (modified)
What I am looking for is some facts about the strength, and axle that will twist under load to take some shock of the gearbox. Let me know if you can help me out here ! Thanks Jon |
GKN does offer a variety of gun drilled tubular halfshafts in various lengths, diameters, and spline configurations. they will also make halfshaft per your specifications that will fit the 930 CV. the 930 CV's are VERY strong. The only time I really ever see them break is under extreme and repeated shock abuse like on the crazy 700hp sand rails.
Adam Hennessy |
That's a nice car.
Frankly, I sincerely doubt you'll have problems with OEM axles with that sort of power unless you're into drag-racing with drag-slicks on prepped surface. Axles only feel actual wheel-torque and you are most likely never to develop enough torque to snap them while racing. With other words, only time you'll get near chance of snapping them is in the 1:st gear, axle-hopping.
Thank you for your time, Last edited by beepbeep; 02-07-2009 at 06:20 PM.. |
Once the car is moving along a track it's highly unlikely you'll ever subject a failure that not extreme wear related.
Adam Hennessy |
This car will not be used for drag racing, but I want to be able to test how quick it is.
Before modification it ran 11,63 sec on ž - and I was only able to test it twice because I broke axle. This time it was on lowest boost and computer setting and on 95 octane fuel. (1 bar pressure) and the car was at that time 1.220 kg. We have made the car lighter all body parts out of carbon fiber plexi glass no stereo no sunroof - . Our engine is more powerful now (was 594hp to the rear wheel on 117 octane fuel and 1,7 bar) but the car is lighter. (That will help our axles :-) ) Have in mind you can ruin the gearbox or even break some part of the engine if you snap an axle!! |
subscribed
The driveshaft shop quoted me around 2700 for axles in my 1991 964 turbo.
![]() There are special drag-racing axles made from spring-steel. They can twist a quarter of turn before snapping. Maybe you should have set of these made if you fancy drag-racing.
Thank you for your time, |
