Rory Mckenna's Avatar
What type KKK turbo is this? will it work on a 930?
http://cgi.ebay.com/ebaymotors/KKK-K27-V-Band-Turbo-Porsche-Motorsports-GT1-959-935_W0QQitemZ120217804090QQcmdZViewItem?hash=item1 20217804090
Old 02-03-2008, 07:14 PM
Turbo Hooligan
well it won't work on a 930 unless you modify your headers and muffler to use v-band clamps instead of bolting together.
Old 02-03-2008, 07:18 PM
Pete,
Do you know what makes this diff from any other k-27?
Old 02-03-2008, 07:19 PM
Turbo Hooligan
the turbine housing on the exhaust side. it attaches to the headers and muffler with a v-band clamp. the standard k-27 for our cars uses four bolts to attach to the headers and four bolts for the mufflers. it could work if you could have your headers and muffler modified for using v-bands. so if you get the turbo at a decent price to offset the cost of having v-band flanges added to your headers and muffler then it would work.
Old 02-03-2008, 07:27 PM
ehh.. I'll keep looking for a standard non mod needed k-27.. thanks bro!
Old 02-03-2008, 07:29 PM
A fellow Pelacanite
NathanUK's Avatar
The inlet looked small to me, but I may be wrong.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-04-2008, 10:32 AM
930gt-40r's Avatar
Rory, I would snatch that turbo if I were you man, I bet that exhaust housing alone would make it spool real quick and I know for a fact that people are making big power with the V-band turbos- V-band technology is the $hit Its worth a little modding to the exhaust...
it will be 2 fasteners to remove the turbo from the car, that alone is awsome
Thats a bad a$$ turbo if the bearings/seals are in working order
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-05-2008, 05:39 AM
Macht Schnell
les_garten's Avatar
The throat looks the size of a stock 3DLZ or older K27 7200 to me also
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 02-05-2008, 07:11 AM
copbait73's Avatar
Les
......and the turbine wheel exducer (diameter at the outlet) looks to be very large. This is a typical hardware match for a racing engine which runs at very high RPM. Doesn't look like something you want for the street.
Old 02-05-2008, 11:34 AM
Brando
quattrorunner's Avatar
Looks bad azz, doesn't the 935 use two of these though? Can you swap out the cold side to make it flow more for single turbo use?
Turbo powa!
1977 911s. it's cool
Old 02-06-2008, 06:49 AM
