bwbolin's Avatar
930 trans fluid what do you use?
I just had my trans rebuild in my 930. It has run Swepco 203 up to this point but Swepco is becoming harder to get here is Seattle. What other opptions are people using and why? Please help.
73 911 E
86 911 Turbo - Sold
01 Boxster S
08 Cayenne S
Old 02-29-2008, 12:45 PM
Smart quod bastardus
fredmeister's Avatar
Swepco 201 exclusively.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-29-2008, 12:59 PM
cl8ton's Avatar
I use Swepco and buy it from Pelican, seems to be always available this way.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 02-29-2008, 01:07 PM
Porsche-Poor
bcoats's Avatar
swepco 201
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 02-29-2008, 01:08 PM
+4
Well that definately is NOT a kodak moment! Hopefully he went easy on you...
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 02-29-2008, 02:36 PM
resident samsquamch
sand_man's Avatar
Swepco 201...
-jeff
Old 02-29-2008, 02:38 PM
bwbolin's Avatar
201 it is
It sounds like the Swepco 201 is perfered by a long shot. Thanks for the help
73 911 E
86 911 Turbo - Sold
01 Boxster S
08 Cayenne S
Old 02-29-2008, 02:48 PM
gearhead
bwbolin,
Just a heads up on 201 versus 203. You will find that a lot of the more performance oriented people use the 201 because it lack the moly additive that you find in 203. There are a lot of people who agree that that additive makes it too slick for the ZF clutch type LSD's.
Furthermore, on a freshly rebuilt transmission it's just not required. If your transmission has an open differential or a torque biasing differentia, a couple of years down the road it may be worthwhile to switch back to 203 as the tranny ages. But if it has a true LSD, stick with the 201 until it's time for another rebuild.
Lastly, I always tell my customers to hold off on installing 201 until they break it in. If you've got fresh synchros in there, you will want to change your gearoil in 50-100 mi. There will be particuate that cuts loose in addition to unforeseen contaminants from the rebuild process. The magnet won't grab everything, and you just spent all that money on a build so why risk it?
Go down to Walmart and get a gallon of their Supertech gear oil. Put that in there for break in and then switch to the Swepco afterwards...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-29-2008, 03:07 PM
bwbolin's Avatar
good info
That is just the info I needed. Thanks very much. I was planning on using somthing for the first 100 or so miles then changing it out.
73 911 E
86 911 Turbo - Sold
01 Boxster S
08 Cayenne S
Old 02-29-2008, 03:36 PM
Registered Abuser
MT930's Avatar
201
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 03-01-2008, 02:24 PM
