LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
polizei's Avatar
I've got a few methanol/water injection questions for you turbo carrera guys:
1. On a 3.2 Carrera with the stock Bosch AFM, is it OK to install the injection nozzle in the charge pipe between the turbo and the AFM, such that the vapor will pass through the AFM?
2. Manufacturer's such as Snow Performance state that liquid cooled engines with methanol/water injection can safely run up to 30 psi boost without an intercooler. What would you recommend is the safe limit for an '87 Turbo Carrera with 8.0:1 compression, twin plugs, stock Carrera injectors & methanol/water injection?
3. Are there any Turbo Carrera guys out there using Methanol/Water Injection?
Andy - 1987 911 Carrera Coupe
Old 09-09-2010, 12:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #321 (permalink)
"Manufacturer's such as Snow Performance state that liquid cooled engines with methanol/water injection can safely run up to 30 psi boost without an intercooler"
NOT
Old 09-09-2010, 05:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #322 (permalink)
Macht Schnell
les_garten's Avatar
Hey, this ain't your slutty sister's Subaru!
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 09-09-2010, 07:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #323 (permalink)
polizei's Avatar
No kidding. That's why I need some advice!
Old 09-10-2010, 04:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #324 (permalink)
sjf911's Avatar
Mine is not a Carrera but I am running a 3.2 intake with 9.5:1 compression. The most boost I have tried is 8lbs with both a full intercooler and meth injection. My intake temps are surprisingly cool (to me) rarely getting over 100F at peak boost. I think the only way to really explore the limit is with an advanced knock detection system and a lot of nerve. I tried the simple knock system available for megasquirt but over about 4500 RPM where I needed it most, it was unusable. If I really wanted to push things I would get the J&S Vampire module. Maybe when the budget allows.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 09-10-2010, 09:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #325 (permalink)
polizei's Avatar
Wow - that's a very cool setup you have. Thank you for your input. I'm not looking to eke out every last HP from my machine - just looking for reliable power.
Did you install your injector in the throttle body? Or before? Do you have an temperature gauge before and after your IC/injection?
Old 09-10-2010, 09:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #326 (permalink)
sjf911's Avatar
I am running a CoolingMist system for injection with a single injector at the outlet of the intercooler proximal to the throttle body. I am running a speed-density EFI so I don't have a "barn door" AFM (MAF) to worry about. Ideally, you would like to have an injector for each cylinder or, at least one for each half of the intake plenum. It is a much greater challenge installing injectors on the intake manifold than on the intercooler piping though. I feel I get better atomization and more uniform distribution of the methanol where it is currently located. It has cost me one MAP (manifold absolute pressure) sensor already as my MAP sensor was located in the ECU and was siphoning methanol. I have since moved my MAP sensor into the engine compartment at a level above the throttle body.
My methanol injector system is only a 2-D map based on boost not load. It has the capacity for 3-D mapping but I can't get an analog 0-5V load signal out of my ECU like what comes from your AFM. I have plans to add a hot-wire mass air flow sensor (MAF) in the future to give me the 3-D capability. The other alternative is to go with MS3 control of the meth injection directly but I already have the CoolingMist controller wired in.
Sapere aude
Old 09-10-2010, 11:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #327 (permalink)
polizei's Avatar
Thanks again for the great info! For now, I'm planning to go with the single injector in the charge pipe in order keep this within budget. I was running OK without an I/C or water/methanol injection before, so I'm viewing this as added insurance.
Right now, I'm thinking about going with the Snow Performance Stage 3 Boost Cooler. The software creates a delivery map based on boost and/or injector pulse width. This sounds like a nice upgrade over systems driven solely off of boost, as it gives you more flexibility to dial in the injection and prevent soak.
Thoughts?
Old 09-10-2010, 06:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #328 (permalink)
sjf911's Avatar
Thoughts?
Hard to tell from the website. It looks pretty much similar to the CoolingMist although I am not certain how the boost/pulse-width injector function works. It still looks like a 2-D map only. You need some other indicator such as RPM input combined with boost or pulse width, or a true MAF signal to generate a 3-D map and tailor your injection. IIRC, the Carrera MAF sensor maxes out at less than maximum mass airflow so may not be usable in this setting. OTOH, I think most meth/H2O injection systems out there are only 2-D including my current setup.
Sapere aude
Old 09-11-2010, 09:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #329 (permalink)
polizei's Avatar
Update
Warning: This post is going to full of "Todd said this" and "Todd said that". Forgive me in advance!
I spoke with Todd at Protomotive this afternoon, and, as always, he was very patient and helpful. I asked him what he thought about using Water/Methanol Injection (WMI) w/o an intercooler on a Turbo Carrera, and he was all for it, provided that the system is installed properly and with safeguards. Great! This seems consistent with the current WMI thread in this forum:
Water / Methanol Injection
I next told Todd that I'd like to end up somewhere in the 400-450 HP range and asked him how he'd recommend getting there for my setup. He advised replacing my stock Carrera fuel injectors with 944 Turbo injectors, upgrading my fuel pump if I should ever want to go past 450 HP, as the stock Carrera fuel pump is good up until 475, and reprogramming my ECU. Specifically, he recommended either a GT2 fuel pump or a Bosch 044 pump. Next came music to my ears... he went on to say that with my setup I'd safely be able to run 1.2 BAR boost! That should get me close to 500 HP
I definitely won't be skimping on the WMI system. Todd has installed a number of WMI systems in the past, including AEM and Aquamist. I'm starting to reach out to guys on this forum who live in my area and have professionally installed these systems. More to come.
Todd mentioned that to fine tune my engine once everything is installed that it would be most ideal to provide him with an air/fuel log as well as ignition data, the latter being of lesser importance. Does anyone know what he means by ignition data? Is this something that most dyno tuners would be able to get a read on?
I'm also starting to think more about replacing my Carrera heat exchangers with headers. I'll have to figure out how to get around the cumbersome 964 dizzy if I do. Todd mentioned that I should be able to achieve full boost 1000-1200 RPM sooner with a set of decent headers. When I had the turbo on previously, I was hitting full boost around 4k rpm. I'm starting off by looking at the GSF headers. Merv successfully ran them on his setup without an issue, but he's not around for a long term update. I'd be curious to hear your input on this topic. I started a separate thread earlier today to kick it off:
Long Term Review - GSF Headers
Thanks in advance.
Old 09-13-2010, 07:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #330 (permalink)
polizei's Avatar
Hey guys,
Quick update. I started the below thread a few weeks ago to kick around whether I should stick with my Montronic ECU, add a piggyback or go to a full blown aftermarket EMS:
Stick with Montronic or go with aftermarket Engine Management system?
Everyone's input pointed to the convincing benefits of an aftermarket EMS, but the cost of it all made my stomach churn! Fortunately, a fellow Pelican was looking to get out of a complete system that he purchased from Chris Carrol of Turbo Kraft. We were able to strike a deal, so I pulled the trigger on an Electromotive TEC-3R customized by Clewett Engineering. Here are the details of the system:
FS: Engine Management ECU Electromotive TEC3 EFI Porsche - USED
I'm really pumped about this EMS! It's going to solve the issues I've had with my stock AFM and eliminate the cumbersome 964/993 dual head distributor! It will also provide me the capability of running a knock sensor, a 3D map for water/methanol injection (WMI), integrated boost control and of course much more controlled, accurate fuel injection and ignition timing.
I'm planning to have Adam Hennessy (BoxxerSix on Pelican) of Rennessy Fabrication do the install and necessary fab work for the EMS, exhaust, intake plumbing & WMI system. I was initially attracted to having Adam work on my car because of his experience with fabrication and WMI installs on 911s. He's been very patient with me and sympathetic to my budget. He's a very meticulous guy and generous with sharing his knowledge. I'm looking forward to working with him. We're tentatively planning the install for late February/March time frame.
Adam recommended going with the Aquamist HFS-3 WMI system. We're planning to have the windshield washer reservoir feed the system, and we'll be running one nozzle on each side of the intake plenum. Here are some additional details of the HFS-3:
Howerton Engineering Aquamist HFS-3
I've decided to go with a set of headers that fellow Pelican YermanCars used on his beast. The headers were built by AMS of Chicago (www.Amsperformance.com), and Yerman made over 500 HP on the headers. He's selling because he went twin turbos. Here's a link to some pictures:
FS: 3.2, 3.3 Turbo headers
More to come!
Old 10-07-2010, 05:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #331 (permalink)
sjf911's Avatar
Sounds like a great plan. I like the idea of 2 WMI injectors, I actually have purchased the parts to convert mine to 2 injectors directly into the intake. I would be interested in seeing how he places the injectors in the manifold. I had my intake out recently to convert over to sequential injection and CNP ignition and looked at it for placement options of the injectors. I decided to defer to a later time though as a solution did not "pop" out at me.
Sapere aude
Old 10-07-2010, 05:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #332 (permalink)
polizei's Avatar
Hi Steve,
Here's when Adam had to say about the placement of the injectors:
Nozzle placement is another trick and is really based on how well the intake manifold can flow. Most manifolds are not meant to flow fluid, and you'll typically get puddling or mis fed cylinders by placing the nozzles too far away. On the 996's I run one nozzle directly into each intake plenum right after the throttle. 930 and 965 turbo manifolds are horrendous at flowing fluid and really need direct port injection. 3.2 carrera manifolds flow better, much like the 996 setup, and I'll typically run the setup much like the 996's. When it boils down to it, it's sort of a "per-setup" basis as to where they're placed in the motor.
Old 10-07-2010, 05:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #333 (permalink)
Nice headers.
Me, I would put an air to air intercooler or maybe a water to air intercooler on it if I had to keep the stock deck lid.
There has to be a reasion this is done over liquid intercooling by almost everyone.
But that is me.
Should be a crazy fast car.
Old 10-07-2010, 06:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #334 (permalink)
930gt-40r's Avatar
Adam is a good choice to work on your car- I was impressed whe I saw his thread involving a 16G turbo for a Mitsu Evo and how he made an anti surge compressor cover for it by hand (looked like a baby HTA 35R...) The car will be mint when he is done without a doubt.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 10-07-2010, 08:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #335 (permalink)
polizei's Avatar
Originally Posted by 911st View Post
Nice headers.
But that is me.
Now that the stock AFM will be removed, that may be a possibility. I spoke to Gerhardt of Bell Intercoolers a few years about customizing an I/C for my deck lid, and he told me flat out that an efficient intercooler could not be placed under my lid. Of course, this was with the provision that the incoming air was blowing over the a/c condenser. A few folks have recommended moving to a 930 condenser and getting a half bay I/C, but again, can you get an efficient I/C to fit under one half side of a carrera tail? Probably not worth the money. The other option is to go with an underbelly condenser. This involves a lot of hassle, and for how much benefit?
I've had a number of folks validate the WMI as a substitute for an air to air I/C. Todd from Protomotive said I'd be good to go as long as I stick to 1.2 BAR or less. I think the most significant reason why a lot of folks have steered clear of WMI is the "what is something goes wrong" line of thinking. And that's totally legit! This is one of the reasons why I'm working with Adam, as he has a lot of experience installing these systems with fail-safes. The TEC-3R gives me even more opportunity ensure that it operates correctly (trim boost or ignition if something goes wrong).
Old 10-07-2010, 08:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #336 (permalink)
polizei's Avatar
Kris, thanks for the vote of confidence in Adam. He seems like the right man for the job.
Old 10-07-2010, 10:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #337 (permalink)
sjf911's Avatar
Any idea on where the injectors are going to be placed in the intake specifically? Are they going to weld bungs in or simply drill, tap, and screw? Any links to pics of 964 or 3.2 install photo's?
Sapere aude
Old 10-08-2010, 07:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #338 (permalink)
polizei's Avatar
Hi Steve,
Good questions. I'll shoot Adam an email and see if he can provide some additional info.
Old 10-08-2010, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #339 (permalink)
polizei's Avatar
Thought I'd post some of my engagement pics from last year. I drove the 911 down to South Carolina where my wife was living at the time to get the pics taken, and the photographer incorporated the old p-car
Old 10-28-2010, 03:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #340 (permalink)
