Looks like a fun project.
75 lb. package sent this morning. The cost on that alone is enough to make your eyes water :(
Andy those look like alusil cylinders but hard to tell but pretty sure:( They should be fine but not as desirable as the nikisil
do me a favor and stick a magnet on the bottom row of studs.. Let me know if they stick. you can also try sticking them to the cylinder walls if it sticks that a good sign if not then you know you have aluisil.. I did on my first setup so it works
Doesn't that mean Dilavar lower studs and steel uppers? The magnet would need to stick to the cylinder itself to be Nikasil. If the magnet won't stick to the cylinder, it is Alusil.
What is the downside of alusil (upside of nikasil)?
Andy, I don't see the support spacer and T-band clamp with your muffler. Give me or Ben a holler if those items were not included.
Andy, where is that shinney blue wastegate? Haha- looks like you are well on your way.
haha
I totally forgot! I was actually upset at myself cuz i got the whole thing laid out (like Christmas morning), put it away, and THEN realized I forgot to throw it in there... I even thought of saying "sorry Kris", but then I was like, "nahhh, he won't even notice." |
The T-band clamp positions the support spacer where you want it and prevents movement once tight. It fits over the tailpipe so is a 3" diameter. If it is missing give me a call. I can also send you some pictures of how it looks when installed.
What is a ballpark figure on the turbo kit? I'm really considering saving for this and want a rough idea what I'm up against.
New Turbo ~ 1100 Used WG ~ 200 New BOV ~ 200 New Exhaust with flanges ~ 700 New Intake piping ~ 100 Used Rising Rate Fuel Pressure Regulator ~ 100 Reconditioned J pipe ~ 200 Oil lines and stuff ~ 100 New Protomotive Ecu ~ 270 Innovate Lm-1 ~ 250 Total is approximately $3000. Always budget an extra bit for shipping and miscellaneous stuff. The real kicker is all the internal work I'm doing on the engine to make it safe for a turbo. |
I appreciate the ballpark. I see myself doing almost the same thing as you when the time comes, engine mods as well as turbo. Time to start saving the pennies...:rolleyes:.
Here is a picture of the spacer and clamp in place on another muffler. This arrangement locks the tailpipe in place and reduces vibration.
You do not need the upper clamp for your application. http://forums.pelicanparts.com/uploa...1205457731.jpg |
