Yes, that's when I did it too. "While it's open" type of thing. Wouldn't do it just for itself, but then again, I don't know anybody who twin-plugged a 930 motor JUST to push the timing and get a few more hp.
Macht Schnell
Refer back to the original Post. All of this references directly to it.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
My turbo is twin plugged, with am electromitive crank fired ignition. When I bought it, it was runnin 1.1 bar worth of springs in the tial without any detonation.
I will say the lower valve covers become a beatch to seal, and the removal of the distributor adsd another wrinkle of potential problems. Bill |
What would you say the the advance should be on a Andial built twin plug w/ 934 type 12 lead distuibuter . Compression 7.0 boost, 1.2 on 100+ leaded fuel now set set at 29 btc @ 4000 RPM
![]() Last edited by voitureltd; 03-06-2008 at 12:48 PM.. |
JFairman said:
Why didn't I think of that,thanks,great idea
![]() This is another very interesting chart coming directly from Porsche engineering SAE technical paper, Hans Mezger, Aug 7, 1978. Interesting, the presentation is discussing geometric compression ratio (fixed C.R.) in terms of.....hold on to your hats power junkies...not throttle response, not boost response, not ultimate power production......FUEL ECONOMY. Posted fuel consumption values are set at low power production (20-30HP ? for a 930 on the interstate). They wanted to maximize engine efficiency at low throttle angles, off boost. High fixed compression delivers this. |
Macht Schnell
I had never seen that graph before but it explains why Porsche picked their CR and Boost pressure settings.
Wo ist die Rennstrecke?
On smaller aircraft engines, like a 540 (cu in), in addition to safety, the twin plug ads to the flame propagation which improves torque. Since the motor red lines at 2700 rpm, you need torque right from idle. In our bigger piston motors (1820 cu in), you need twin plugs just to light the fire without reverting to 45 degrees of advance. Last edited by DonE; 03-07-2008 at 06:53 PM.. |
Don, your high mod engine at 8:1C.R. is another data point. What boost and HP are you running? Are you running dual plugs? Thanks
I run .8 bar at 500 rwhp. At 1 bar, 525 rwhp. My ignition is twin plug, wasted spark, Bosch coils, LINK ignitors.
Crotchety Old Bastard
500HP @ 0.8bar, damn Don that is sweet! If memory serves you're using a GT35. Looks like they work well!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 03-07-2008 at 08:07 PM.. |
Adrenaline Junkie
![]() Quote:
I am huge proponent in doing pre-flight to my car or motorcycle each and every time I take it out. Of course, imminent power failures are far easier to deal with on four wheels than on two wheels,, let alone being in the air. Good tip, Rob. ![]() |
Thread Tools | |
Rate This Thread | |
