DCR Rides
mdripley's Avatar
Alternator Warning light Diode?
Hey everyone, I am looking to what others have done to replace the diode, or safeguard the warning light circuit, if the diode is removed?
I know others have ran into this issue, But not how they resolved the issue, I am concerned about deleting that diode, leaving the circuit unprotected.
Regards
Mike
87 930 turbo coupe 3.3L , 4Spd 930 Trans w/LSD , mostly stock for now
Old 09-01-2013, 11:30 PM
Turbofrog
smurfbus's Avatar
There are lots of thread on this diode here and at the technical forum. I think it's needed for the alternator to start working correctly and so does the red bulp. I think I once had it the wrong way and alternator did not work. Hope someone more smart will chime in for the real answer : )
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-02-2013, 12:01 AM
Ken911's Avatar
OK I went through this. You can just pull the diode out, and bypass it until you find a new one. I took me a year and a half. should be about a few dollars there were a couple people on here who offer to sell on at an outrageous price so I passed until someone had one for a reasonable price. If you don't replace it or hard wire past it the alternator will not charge the battery.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 09-02-2013, 01:54 PM
DCR Rides
mdripley's Avatar
Thanks for the advice. I have a replacement on the way. I have a temp Diode that I soldiered together from Radio Shack and it works fine.
Now if my CD box would behave
Mike
Old 09-02-2013, 04:07 PM
Crotchety Old Bastard
RarlyL8's Avatar
I went through this a few months back with the gray ghost. Someone sent me the part numbers needed to reproduce the diode/wire using RadioShack new parts. That email is long burried now but the parts do exist to make an inexpensive wire that does the job. There are a few EE here on the forum that can tell you exactly what is needed.
Old 09-02-2013, 06:11 PM
speednme1's Avatar
here try this link...has pics and part# to make your own Light Help PLEASE!! - Rennlist Discussion Forums
Rey....77 930 "the Mistress"
Old 09-03-2013, 02:51 AM
Tinkering Pays!!
mooney265's Avatar
Here you go: Alternator light doesn't go out after startup
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-03-2013, 07:56 AM
DCR Rides
mdripley's Avatar
Thanks to all for you input on this issue.
I have resolved the issue by making my own replacement diode(s).
I used the diode pn 1N4002 and soldier on the connectors and covering in shrink tube, It works great as soon as Installed upon start up the alt light went out and the alternator started charging the battery 13.4 to 13.9 volts at 2000-2500 rpm.
these diodes are used in other locations as suggested by the link to the rennlist thread on this subject (see post 7). easy to make cost less than a dollar for all components.
Regards
Mike
Old 09-03-2013, 12:56 PM
