3 restos WIP = psycho
kenikh's Avatar
Originally Posted by hobieboy View Post
I understand that knock sensing system needs to be tuned to recognize knocks?
So a question for those who installed a system - is my understanding correct? If so, how did you tune it the 1st time? Make the engine knock?
You can apparently ballpark the frequency by piston diameter, but the actual variables are numerous and require advanced math to resolve. Here's a start:
Resonant knock frequency (kHz)= 900/(pi x cylinder radius)
http://www.phormula.co.uk/KnockCalculator.aspx
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-08-2009, 06:57 AM
930gt-40r's Avatar
subscribed...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 08-09-2009, 06:54 AM
Super Moderator
nize's Avatar
and that, really, is the 'secret formula'...
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-10-2009, 11:16 AM
Project 935 Blackbird with knock controller. Claims 900 hp at 1.6bar
I'm pretty sure the engine was done by Turbo Mike in SoCal. He installs the knock controller between a F.A.S.T. EMS and two MSD7's.
Reader's Digest condensed version:
http://www.6speedonline.com/forums/930-turbo/179696-reapers-blackbird-build-chronicle.html
Long thread:
Reaper 935 'RSR' Project
Old 08-13-2009, 04:32 AM
I just bought a pair of bridges. Much cheaper than expected and available on Pelican! $45 shipped for two!!!
What is the part number for the bridge you got at Pelican? I couldn't find it.
Old 10-27-2009, 07:33 PM
kenikh's Avatar
Here you go: 993 104 391 00
Pelican Parts - Product Information: OEM-99310439100
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-28-2009, 07:48 AM
sjf911's Avatar
If you are only going to run 1 sensor, why not place it somewhere on the case?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-28-2009, 08:29 AM
Did I mention we have a 30 day money back trial?
I will waive the normal 10% restocking fee to the first one that orders.
Old 10-28-2009, 08:46 AM
kenikh's Avatar
If my motor were anywhere close to ready, I'd take you up on it! Unfortunately, there is no way I'd come close to making 30 days.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-28-2009, 08:51 AM
Any idea if this will fit a 930? I assume it will.
Old 10-28-2009, 09:54 AM
Wouldn't putting two sensors, one on each cylinder bridge, be more accurate?
Where are people placing them otherwise? I read about the crankcase breather but I'm not sure where that is located. Anyone have a pic of that area?
Old 10-28-2009, 09:58 AM
kenikh's Avatar
For starters, yes, you need two, once on each cylinder bank, just like the 993s do.
Second, these will fit any 911/930, as long as you drill and tap the underside of the cooling fins so you can bolt these solidly to the cylinders.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-28-2009, 10:07 AM
sjf911's Avatar
But then wouldn't you need 2 separate controllers?
As an aside, can a single J&S unit run 6 coils on a twin-plug wasted-spark motor controlled by MS-II and parallel EDIS units? I already have a Bosch sensor on the case oil breather cover running a KnockSense module that has already given up the ghost.
Sapere aude
Old 10-28-2009, 10:27 AM
Please post or mail me a wiring diagram.
See the two links at the top of my home page for waste spark or coil on plug applications. One of these should be able to do the job.
Old 10-28-2009, 10:36 AM
sjf911's Avatar
This is from Mike's build but it is basically the same as mine:
Sapere aude
Old 10-28-2009, 12:41 PM
To retain dual plug waste spark, you would need two three channel Vampires.
We have a single box version for dual plug with twin distributors.
Old 10-28-2009, 01:08 PM
Wer bremst verliert
JohnJL's Avatar
That's my diagram above, I dont use MS anymore, but similar setup through my Adaptronic ECU. I use two triple-channel Haltech ignitors. When they work they're great but I've had some QC issues.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-28-2009, 01:38 PM
JohnJL:
The Adaptronic has three outputs that go to two three channel igniters?
The Interceptor version will work.
Three inputs from the Adaptronic, three outputs to each igniter.
Old 10-28-2009, 02:43 PM
So what about this John? Would I need 2 controllers or can I parallel the knock connections somehow to use 2 sensors on 1 controller.
Old 10-28-2009, 04:25 PM
forwheeler:
You have the same set up as sjf911?
According to the drawing posted, you would need two three channel Vampires.
Old 10-28-2009, 07:39 PM
