LinkBack | Thread Tools | Rate Thread |
Slantnose from HELL
I agree the wasted spark coils are by far the cheapest way to go. I already had my billet dizzy so I stayed with it. Possibly I will end up going to COP's at a later date. If you have nothing to start and need to decide what to do then I'd go with wasted spark use a hall effect crank trigger and a Ford hall effect cam sensor along with the adapter to mount it to the cam tower. This would definetly the cheapest. If you want to step it up a notch COP's which would not require sparkplug wires. But you would need valve covers to mount the COP's. Hargett Percision Products makes billet valve covers that mounts Ford COP's.
It changes from time to time..... |
Macht Schnell
Very sweet, what Program did you use to diagram this out with?
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Macht Schnell
Wo ist die Rennstrecke?
My problem was me. I had a poorly crimped 12v supply and it finally failed. Fortunately, the LINK tells me which trigger has an error so I was able to tell what was going on immediately.
For what its worth, if I had to do it all again, I probably would have saved a bit more money and gone with some sort of CDI ignition. I currently use wasted spark and it works well, but I think I could get better drivability and torque with CDI. To improve idle and high RPM drivability, I reduced the gap on my plugs from .028 to .023. It smoothed my idle out but I haven't tried the high rpm yet. It's a good thing I have dual plug with this ignition system. |
Nathan,
If you haven't found it yet, here's a pretty good thread on a dual plugged MegaSquirt II installation with some pictures on sensor installation, some sample fuel and ignition maps and lots of Q&A from folks on the forum. Megasquirt setup for 930 and dual plug EDIS Noah, great work on the illustration - that will help a lot of folks. I've been running MSII for a couple of years and have been very happy with it. Good luck!
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) Last edited by mppickett; 07-03-2008 at 06:37 AM.. |
resident samsquamch
Yeah, I agree! That was a pretty impressive post, from Noah!!! Being that I'm running so well on my modified CIS system, I'm a long way off from an EFI conversion, but stranger things have happened...
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
A fellow Pelacanite
Thanks Guys!
I have to admit, I forgot to search the 911 forum...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Belive it or not, MSpaint. Paint is great for doing simple little diagrams for your own notes. I can make them with cad or ProE but paint does a great job for this and it's easy to use.
1985 Porsche 911 M491 option 55K miles 1985 Alfa Romeo GTV6 CRG Heron Daytona CR125 Shifter Kart |
The knock sensing module I am still working with, I think it should be fine but I might need to add a fuse on the +12V power line off the main relay. Also, there is a chance that I will have to add some sort of signal conditioner to dampen out noise that is from normal operations. I see no reason why we can not have knock sensing on our engines. Thanks, I try to be of some help. I guess it is in return for some of the overly inquisitive post I make from time to time.
+1, nice work Noah.
![]() Twin Plug Goodness...Look what I made this weekend!
'77 S with '78 930 power and a few other things. |
