Random Turbo Questions
Whats going on Turbo guys, while the Boxster does not have any turbo aspirations, I'm still a huge fan of the old school aircooled monsters. I have a few quick questions that have been circling around this dense head of mind.
1. With replacement intercoolers, I see that the insulation around the IC is never present. Does losing this strip reduce the efficiency of forcing cold air throught the AC? Any thoughts on the RUF IC, it looks almost stock 2. SC guys are always talk about upgrading the trumbone cooler to the Carrera variety to reduce temperatures. Is this an issue with the early turbos? 3. Regarding the non IC 3.0's, how is the performance compared to later cars? can you get away with moding them without the IC. I met a guy with a 76 that stated he a motor making 500+ with no IC! Ok thats enough for the day( damn I need to get a life), hope you guys have a great weekend.
“I will drive flat out all the time. I love racing.” - Gilles Villeneuve |
Macht Schnell
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
