What oil to use in a 930?
Hello all,
first things first: Newbie in the forum and I've recently purchased a 1985(6) 930 with 33k km's (about 20k miles) which is in a very nice condition - 999 being one of the options
Now would be the time to change the oil to the car and I did try to search from this forum and from the net but did not find what would be the recommended oil to use in the car? (Outside from the factory recommendations that is if newer oils are better that is)
Apologies in advance if there already is above information in this BBS
Thanks in advance!
Old 09-02-2008, 10:09 AM
Max Sluiter
Flieger's Avatar
Synthetics are good for the higher temperatures of Turbos but only the more expensive racing oils have enough zinc and phosphorous to keep the upper valvetrain protected from severe wear. The racing oils need to be changed more often, though, because most of them do not have the detergents to keep a street engine clean.
Most people follow Charles Navarro of LN Engineering and use 20W50 Brad Penn partial synthetic It is the new name for the old Kendal GT1. It has the best mix of zinc, phosphorous, and cost.
That said, there are better oils (Shell Rotella, I think) but most cost a lot more than the Brad Penn. Motorcyle and Diesel oils are another option but most are not entirely suited to our applications.
Read more at http://www.lnengineering.com/oil.html
and get some Red Bull and a comfortable chair to read the ultimate oil thread:Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
Old 09-02-2008, 10:19 AM
Flieger,
thanks for pointing me to the right direction.
Need to spend some time to read that thread.
Thanks again, appreciated!
Old 09-02-2008, 10:36 AM
resident samsquamch
sand_man's Avatar
Brad Penn 20W-50 in mine...
-jeff
Old 09-02-2008, 10:57 AM
After reading all the information available.. it seems to me that it comes down to Mobil One V-twin 20w-50 being the best of the best.
It is still high in ZDDP because motorcycles don't have catalytic converters yet, and it's synthetic so it has a higher flashpoint than non synthetic oil.
That lowers the chance of oil carbonizing in the extremely hot turbo bearing housing after shutting down the motor.
Also, it is made for the localised heat of air cooled motorcycle engines... alot like our engines.
You can usually find it in the small motorcycle section of Walmart for around $8.50 per quart, or a little more at auto part stores.
Second best seems to be Brad Penn 20w-50.
Some people say it's the best and they are usually the ones using it or selling it.
It is definately one of the best choices and cost alot less than the best synthetics.
Valvoline racing oil has always been good too, and probably still is. They call it VR1 off road racing oil nowadays.
Amsoil is considered possibly a little better than Redline and Royal Purple racing synthetics... but who really knows.
It seems the formulations may be getting changed at least once a year these days.
Old 09-02-2008, 11:57 AM
Oil
I've never seen that in the auto stores around here, who stocks it?
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-03-2008, 06:27 PM
mobile 1...good enough for the faa...good enough for me.
Old 09-03-2008, 06:37 PM
Max Sluiter
Flieger's Avatar
Brad Penn distributors are a little farther apart. There are a couple in Southern California- TRE Motorsports and TLG Auto.
I bought mine from Charles Navarro of LN Engineering in Momence, Illinois. He has helped contribute so much information to the oil thread.
I was surprised how reasonable the price was per quart even shipping half way across the country. Not much more $ than the weak Castrol GTX I was getting from Pep Boys down the street. The green oil performs much better, though.
Old 09-03-2008, 07:46 PM
Blitzkrieg
jly535's Avatar
+1 for Mobile1 20-50 V twin motorcyle oil, I use it in 930 for 1500 miles then recycle it into my Ducati 50/50 with new oil. I order it online by the case, and it usually works out to about $8 per quart after shipping.
Old 09-03-2008, 08:33 PM
resident samsquamch
sand_man's Avatar
I order it by the case from a shop in Concord NC. They have an ebay store, as well:
http://cgi.ebay.com/ebaymotors/BRAD-PENN-GREEN-OIL-Rat-Rod-Engine-Motor-Oil-Swepco_W0QQcmdZViewItemQQcategoryZ107067QQihZ019QQ itemZ290257031198QQrdZ1QQsspagenameZWDVW
-jeff
Old 09-04-2008, 05:58 AM
+1 Mobil One V-twin 20w-50 also
http://www.torcoracingoils.com/Products/ProductView.aspx?id=d88b58e3-8f03-4fe9-8029-728fe025d0c3
Been using this in air cooled flat tappet Type 1 & 4 VW racing motors with zero flat cams
Old 09-04-2008, 07:43 AM
Auto Zone carries Mobil One V-twin 20w-50
pricey for my 965 but its easy access ...
Old 09-04-2008, 07:45 AM
Anyone have an online source for Mobil 1 V Twin 20W-50? JLY535, you said that's how you got it...
Rob
Edit: just did my own seach; found Amazon has it for $49.69/6 qts, including shipping. That works out to $8.28 ea. The local Autozone wants $9.49/qt. Yikes, this stuff is expensive.
Old 09-04-2008, 10:53 AM
Here we go again.... ++1 Mobil1 15-50 all the way.
Old 09-04-2008, 11:36 AM
Wally world has Mobile 1 15-50 for 26 bucks in a 5 quart jug.
63 356 So Called Outlaw
76 930
Old 09-04-2008, 11:50 AM
Blitzkrieg
jly535's Avatar
Rob
I believe I bought it at Autobarn.com, Most Autozones stock it as well.
Old 09-04-2008, 12:03 PM
Smart quod bastardus
fredmeister's Avatar
Whats wrong with Castrol GTX 20W50 and not running it too hot?
IF the oil cooler is adequate to manage temps to under 230 degrees and you let the turbo warm up and cool down after a drive is this oil detrimental?
Doesn't GTX still have the proper amounts of zinc and phosperous for the rocker arms?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 09-04-2008, 01:28 PM
Guys,
If you're thinking of using standard Mobil 1 or Castrol GTX in a "flat tappet" engine like a 911 or 930, you really need to read the threads mentioned above by Flieger in Post #2. That will explain why it's worth paying all this money for oil.
Rob
Old 09-04-2008, 02:06 PM
Max Sluiter
Flieger's Avatar
According the THE OIL THREAD Castrol GTX has been reformulated with much less Zinc and Phosphorous. The high levels of Calcium detergents also impede the effect of the zinc and phosphorous to form ZDDP.
I move that we transfer this discussion to the big oil thread to avoid repeating a long discussion.
Old 09-04-2008, 04:29 PM
Banned
Royal Purple Max Cycle is the oil for me.
Old 09-04-2008, 06:45 PM
