Identify Injector connections CIS
Hey all, I have a 81 euro 930. Behind the CIS housing are three (3) injector connections but I only found two plugs. I think the connection on top of the CIS housing is some form of fuel shut off? There is a cold start valve to the right of that in the center of the housing and then below the cold start valve in the center of the manifold, there is a regular bosch injector- does this sound right? Any help in identifying these parts would be helpful. Also, the plugs were unplugged so I have no idea were they connect. Everything looks factory, as far as I can tell.
A fellow Pelacanite
Do a search, I've posted all the correct colours before and my memory is bad...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
A fellow Pelacanite
Green connector goes to the CIS.
