Cracked Headers
How can a person tell if their headers have cracked in a place that is not visible without having to take them off the car? Are there any obvious symptoms a person would notice?
Acceleration Junkie
Yes, you will hear an exhaust leak, especially when the engine is cold. If a small crack, it will usually seal itself with expansion from heat. If your engine gets quieter as it warms up, probability you have an exhaust leak is high.
What sound would it make? Some popping?
resident samsquamch
In many cases, it sounds like you're driving an early air-cooled beetle....
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
resident samsquamch
Might also look for signs of exhaust carbon/soot.
It's a 914 ...
Another option, which I used to do a lot of in my 914/4 ownership days to diagnose exhaust leaks ... take a several foot length of small diameter hose, like fuel hose, and use it sort of like a stethoscope for exhaust leaks. Put one end sort of near your ear (not too close!), and probe around the suspected leak area with the other end of the hose. When you get near a leak, you'll hear a clearly audible puff-puff sound. Works like a charm.
Scott |
A fellow Pelacanite
I'm just guessing here but if you turn on your heater to defrost and aim only at the screen, if it's leaking you should get vapour on your windscreen?
Plumbers check gas flues with a mirror, any steaming up and you know it's leaking fumes... Try it out on the tailpipe to see if my theory is correct.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
resident samsquamch
BTW, what type (brand) of "headers" are we talkin' 'bout?
I once had a leak and it made a tap-tap-tap-tapping noise.
Forced Induction Junkie
![]() Visually, you'll see white traces where the hot exhaust is escaping. Must common areas are the slip joints, welds for the heater boxes and collectors.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Yea those B&B's with heat always seem to crack right at the spot tig welds where the affix the sheet steel that forms the heater boxes. Wish-wash headers in my opinion
Adam Hennessy |
At the shop we have a smoke machine. Pump the smoke into the tail pipe and shine a spot lamp around to find the source of the smoke. Saves getting burnt on hot exaust.
I don't know. I haven't had any other types of manufacturer's headers on my car, but these held up over a period of 6 years. No track days, btw. I don't like any of the heater box designs by GHL, B&B. They weld the boxes across all the tubes which is a disaster waiting to happen. FabSpeed has new headers out, but they appear to be of same design as the others.
Smart quod bastardus
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
fredmeister,
It's not that there's an apparent flaw in the welds, it's the heat cycles the headers w/heat boxes go through. The very hot header tubes are expanding at a different rate than the cooler heater boxes. The expansion and contraction routines these headers go through will weaken and then crack the weld at the box, or worse, crack at the header tube, creating a hole. If I could get an alternative heat source (don't need a lot...not driven in winter), I would definitely use headers w/o heater boxes
Plus 1 on what Dave says- did you see the ones that GSF has? They weld all the way around the primary to the heater-box! At least my old B&B's have a small tack-weld that may have a little give to it. As far as heat-sources go, I have been toying with the idea of an electric coil type heater, but dont want to strain the alternater. Then I have even thought of making a "heater core" that had oil pass through it, but it would take forever to get hot. If anyone has any ideas for this, please let me know.
P.S Protomotive makes a collector that goes over the stock engine mounted oil-cooler and gets hot air from there, unfortunatly I am doing away with the engine mounted oil cooler.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Kris, I recently tried to get one of the Protomotive engine mounted oil cooler boxes and got this reply from Todd (he's a good man, always replies straight away):
"We’ve found a simple plate hung off of the rear tin that draws heat from the back of the cylinder head to be just as effective and stopped manufacturing the oil cooler heaters." I replied asking for more info and if he would fab one for me and got this back: "No, sorry we’ve just fabbed them when we need them on the cars. I don’t have any fixturing for them, nor any older 911’s around to even fab one on. We seem to be doing only 996tt/997tt’s lately. A simple plate, hanging down from the rear sheet tin with a tube welded on the back that you can attach the heater duct to. It’ll just draw the hot air coming off of the bottom of the cylinder head and exhaust system." I'm going to give it a try, just can't get my head around it right now, man the car didn't do many miles this last winter, too cold in there. I've been meaning to ask Brian if he can fab something like this up. You persisting with your car Kris?
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Yea Spence- I couldn't stay away from it. I ended up getting a set of nice cyls and actually spent the money on the head work and am now re-assembling her this week. I swear, these cars have to be more expensive than drugs and are more addictive. I should have her done in a few weeks- thank you for asking.
Crotchety Old Bastard
SSI makes the only 930 heat exchanger I know of that actually produces good heat and does not have welded primary joints within the exchanger housing.
They aren't OBX/GSF price point; you get what you pay for. ![]()
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
