source for tach signal in engine bay?
Is there an obvious/easy source I can tap into in the engine bay to pick up the tach signal/same signal as the tach would receive?
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 11-16-2008, 04:04 PM
A930Rocket's Avatar
By the CDI box and running on the frame rail towards the front, there us a black wire with a purple stripe. If I'm not mistaken, that wire goes to the tach. It also has a connector in that same location.
Old 11-16-2008, 05:04 PM
Thanks for the tip! I will check that location for the wire and see if does the trick.
Emery
Old 11-17-2008, 05:00 PM
Wer bremst verliert
JohnJL's Avatar
Coil neg terminal. Depends on your signal requirements. WHat are you using it for?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-17-2008, 06:33 PM
Using it for the Digital WUR RPM module.
Signal requirements...I'll have to check the manual later, unsure off the top of my head.
Emery
Old 11-18-2008, 04:27 AM
