Banned
Intercooler O'Rings Lube
Hello,
Is it necessary to use a special lube on the various orange, intercooler O' rings, or can one use lithium grease?
Ronnie
Old 12-29-2008, 05:53 AM
A930Rocket's Avatar
I use silicone spray. Stay away from any petroleum based lube.
Old 12-29-2008, 06:37 AM
Banned
Thanks - will do!
The main O'ring that really needs lube is the one that goes on the inside of the aluminum adapter for the K27 HF and the up-pipe . . . no joke, I must have about 8 hours (and a couple of torn seals) into fitting that damn thing !!!
R
Old 12-29-2008, 06:48 AM
Originally Posted by Ronnie's.930 View Post
Thanks - will do!
R
But of course...we all know that we need the "right" lube when handling our pipe!!!!
Old 12-29-2008, 07:04 AM
Crotchety Old Bastard
RarlyL8's Avatar
I use silicone grease.
Old 12-29-2008, 08:10 AM
Banned
"But of course...we all know that we need the "right" lube when handling our pipe!!!!"
Speak for yourself, slow&rusty; most any lube will work for my "pipe" !!! ; )
Old 12-29-2008, 08:15 AM
Send a message via AIM to Ag02M5
Hmmm. I used Mobil 1 synthetic grease...sounds like the wrong choice?
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 12-29-2008, 08:28 AM
I recommend "brake master assy" lube It is designed for seals/orings. The fine oil will not break down the seals. Your local Napa should have this in stock. Raybestos brand.
The lube is nice to have around the shop. It can be used for most viton seal installs.
Kevin
Old 12-29-2008, 09:24 AM
Smart quod bastardus
fredmeister's Avatar
I use good ole vaseline.
Those seals are exposed to motor oil, so I don't see how petroleum based grease is any danger, unless soemone can explain I am missing something.
Lithium would work too, but you want something with a little stick and vaseline has more viscosity.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-29-2008, 01:50 PM
Silicone o-rings will swell if you soak them in some petroleum based solvents, especially gasoline.
I've never soaked one in motor oil or petroleum base grease for a while and measured it with calipers to see if it swelled but there's a chance it will eventually.
I think the best thing to lube them would be silicone grease like you can get at some hardware stores or scuba dive supply places.
Vasaline would also work. It might liquefy at a much lower temperature and run off though.
A friend of mine installs swimming pools for a living and the pool pumps use alot of o-rings and he always has extra little plastic bottles of thick silicone oil made for installing 0-rings that come with new pool pumps and valves.
It works real well and has a thick viscosity kinda like STP.
Old 12-29-2008, 03:05 PM
The last time I changed out the o-ring I went dry... This was after I cut two with lube and said what the Hell.
Old 12-29-2008, 03:32 PM
A930Rocket's Avatar
Yeah, for some reason that one is a ***** to get on. Wait until you try to remove...
R
Old 12-29-2008, 03:40 PM
Banned
"Yeah, for some reason that one is a ***** to get on. Wait until you try to remove..."
The adapter has been on and off more times than I care to count - and I have several torn O'rings to prove it !!!!! I now keep quite a few of those on hand !!!
Ronnie
Old 12-29-2008, 05:38 PM
RarlyL8's Avatar
I remove the adapter O-ring and thoroughly coat it with silicone grease. Re-install and index with soft taps using a rubber mallet. Once indexed a couple of firm blows seats it. Takes just a few minutes and a little patients.
Old 12-29-2008, 06:29 PM
Me like track days
Craig 930 RS's Avatar
SiliGlide from NAPA, hands down the best.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-29-2008, 08:30 PM
