Me like track days
Go with 7.5 Mahles, you won't regret it.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
A fellow Pelacanite
HotRod, you could of course go with 8:1 if you want better off boost response and run less boost until you went EFI.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
The stock 930 intake port in the head is about 36mm but it necks down to about 32mm at the intake.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 12-05-2008 at 02:14 PM.. Reason: Clarification |
Yeah, mine necks down to 33mm right at the intake, I haven't measured the plastic spacers yet to see what they are...or the heads
I'm magnesium welding my stock intake and then open the ports. Well actually Kevin at UltimateMW will do the porting.
Why the welding, wouldn't extrudehone clean them up and then just machine the intakes to whatever you want them to be?
I'm opening the ports to 41mm and so I need the extra alloy around the ports.
Stock intake does not have enough material around the ports to adequately seal after the porting is done. |
Infidel
My intake manifold was ported, along with the heads, don'tknow to what size though. This is a pic of a ported 930 manifold, not mine. Don't know if you can tell how much has it's been opened up from this shot?
My ports look about that size and they are ported to 36mm. I'm doing an EFI conversion with bigger valves and 41mm ports on the heads. I'm also using 76.6 mm stroke crank and 98 mm mahles P/Cs for ~ 3.5L. It took weeks to nail down the magnesium welding technique.
Thread Tools | |
Rate This Thread | |
