				tranny help
			Let me give you a quick rundown on what I've done to my tranny and maybe someone can give me some direction on where to look..
				History.. a month or two ago while at the track my tranny stuck in between gears.. Upon tearing it out I discovered that the reverse gear ( the one in the nose of the tranny between the two main shats) had popped the retaining clip and torn out part of the sleeve.. So I replaced that sleeve and clip. I also took off the center section of the case to check that all was well ( it was). I returned the top nuts that hold the two main shafts to the original positions and secured the nuts. Upon putting the engine back in there is a distinct noise when the clutch is released it does not make a difference what gear Nuetral too!!!.. SO I pulled the engine again thinking it was a problem in re-assemble,, but no luck and when I turn the tranny everything sounds smooth, and it shifts well.. Since the noise goes away when I depress the clutch , could it be the throw out bearing needing lube or going bad ? I'm at a loss here.. Any ideas ?
	"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon  |
			Could be the throw out bearing. I have seen them make noise with the clutch out before.
	I am not sure about the 930 transmission but is there a way to check and adjust the input shaft end play as well?  |
			I was thinking throw out bearing, would it stop the noice when I push in the clutch ?
			No way to to adjust the play that I know of on the input shaft.. but I'm no expert. T
			 930s rule the wasteland
			my guess shift fork or somthing is misaligned or loose in the case
	1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI  |
 Spoke with Chris Bennet and we're thinking now that perhaps the reverse fork got bent , as there was enough force to break the clip ring out.. and we're thinking it doesn't take much mis-alignment to have some rubbing.
			ill put the farm on that
