9dreizig's Avatar
Send a message via AIM to 9dreizig
tranny help
Let me give you a quick rundown on what I've done to my tranny and maybe someone can give me some direction on where to look..
History.. a month or two ago while at the track my tranny stuck in between gears.. Upon tearing it out I discovered that the reverse gear ( the one in the nose of the tranny between the two main shats) had popped the retaining clip and torn out part of the sleeve.. So I replaced that sleeve and clip. I also took off the center section of the case to check that all was well ( it was). I returned the top nuts that hold the two main shafts to the original positions and secured the nuts.
Upon putting the engine back in there is a distinct noise when the clutch is released it does not make a difference what gear Nuetral too!!!..
SO I pulled the engine again thinking it was a problem in re-assemble,, but no luck and when I turn the tranny everything sounds smooth, and it shifts well..
Since the noise goes away when I depress the clutch , could it be the throw out bearing needing lube or going bad ? I'm at a loss here..
Any ideas ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-07-2008, 10:01 AM
Could be the throw out bearing. I have seen them make noise with the clutch out before.
I am not sure about the 930 transmission but is there a way to check and adjust the input shaft end play as well?
Old 12-07-2008, 10:19 AM
9dreizig's Avatar
I was thinking throw out bearing, would it stop the noice when I push in the clutch ?
No way to to adjust the play that I know of on the input shaft.. but I'm no expert.
T
"Todd"
Old 12-07-2008, 10:37 AM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
my guess shift fork or somthing is misaligned or loose in the case
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-07-2008, 04:01 PM
9dreizig's Avatar
Ok so I went out and started it up,and got underneath with a large hose so I could pinpoint the source. It is definately coming from the nose area..
Spoke with Chris Bennet and we're thinking now that perhaps the reverse fork got bent , as there was enough force to break the clip ring out.. and we're thinking it doesn't take much mis-alignment to have some rubbing.
"Todd"
Old 12-07-2008, 04:45 PM
h20cooled7's Avatar
ill put the farm on that
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-07-2008, 06:18 PM
