LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average.
Originally Posted by IMONBOOST View Post
BTW - Looks like we might need to keep the arm to reduce the torque required by the servo motor.
I think so, even if we totally bypass the WUR by tying the lines together to get the lowest CP, the plunger will still need a little force to operate, and the lever ratio will help. It might also help with resolution, large arm movement, small plunger movement.
Regardless, it will not interfere with air flow because air will no longer have to go thru the whole FD, plunger box assembly, all we have to do is put an Air filter straight to the turbo inlet go BOV to atmosphere. Just thinking out loud.
That would clean things up nicely! But if you use a MAF, that may add a little plumbing, but not much. Just your typical MS1 with the built-in MAP might be easier for a prototype.
Like you, I think the trick is the proper actuator setup, with good resolution and accurate control, the electronic contol of actuator should be fairly easy.
Looking forward to your progress!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 09-25-2010, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #301 (permalink)
Dose that take us back to using a Frequency Valve. Again-- cheap parts, developed controllers, very accurate, and fast acting.
One other issue with keeping the Control Plunger is if you want to move it quickly like between shifts if it is an older FD, control pressure will spike as you try to advance the plunger. Same with closing it, there will be a level of neg pressure behind it keeping it from moving quickly.
It really would not be hard to make a manifold to occupy the space of the 17mm control plunger that would tap into the supply pressure and feed the metering ports.
Old 09-25-2010, 01:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #302 (permalink)
Somthing like this:
Old 09-25-2010, 02:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #303 (permalink)
vas930's Avatar
Just a bump for this thread.
A great read for the new guys like myself.
79 Silver 930 SOLD
Old 11-25-2011, 03:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #304 (permalink)
