LinkBack | Thread Tools | Rate Thread |
Old thread but same problem. What is this? From the 7200 it looks to be a K27 but whats the deal with K2? Its installed in an 89 930.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS 1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE. 2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK" |
Normally there is K27, it's in the box "Grösse" (means size), so I suggest there is only a "7" missing. Maybe try to look more precisely if it's there
K2 would, if exists be very small
Roland 930 Turbo '81 Too many modifications to list |
Here a copy from a old threat at rennlist regarding my K27 turbo.
Maybe we can collect the different KKK data. -------------------------------------------------------------------------------- I recieved some more info on my "exotic" turbo: 935.123.025.01 K27.2 - 3004G11.11 90011 0059 5327 999 1206 Borg Warner indicate this part as a prototype for Porsche Motorsports. One interesting point is that the casted turbine housing contains more NI (nikel) to allow more heat for motorsport applications. For dimensions: The turbine wheel outlet is 60mm, same as K27 7200 in a 11.11 housing The compressor wheel size is extracted from the 3004 number , its the first 30, which says 30x 1/10 inch = 76,2mm. Same as K27 7200 Only the trim, extracted from the 3004, here the 04 seems a little uncommon. These last two digits give the percentage of the compresor gradient. In this case 4%. The K27 7200 has 72 %. Whatever that means in performance?? Maybe the specialists can comment this? Overall the BorgWarner people feel, that this turbo was one of the prototypes for the K27 7200 tested at Porsche Motorsport. Falk
87 930 bblk/blk 88 3.6 white/blk |
Thanks for the replies. I just started a thread to get some info on Imagine Auto. This turbo was from them, they have apparently closed so its kid of a dead end. It was installed by the PO back in 2004 along with a 360 hp kit.
